Cranking but won't spark
hoodedreeper
Re: Cranking but won't spark
Postby hoodedreeper » Mon Dec 05, 2016 1:03 am
I dont know for certain if everything else was tested with the ECU,Reverant has been abit vague with the repair carried out.
The CAS was purchased from a breaker,but i swapped it back to the original that was on the engine. The ignitor unit and coil pack were swapped from my running daily driver. The current coil pack on the daily is the one from the purple car,and i've had no issues
Postby 93_Clubman » Tue Dec 06, 2016 11:23 am
hoodedreeper wrote:car will spark in the test mode via Tuner Studio but it won't spark while cranking.
How does Tuner Studio test mode get the car to spark, ie what components is it using in test mode?
hoodedreeper
Postby hoodedreeper » Sat Dec 10, 2016 6:11 am
So after almost 3 months of trying to fix the car i gave in and dropped it off to H&S Performance for them to look at it. Within 20 minutes they had it running.
Y'know how you kick yourself over something ridiculously simple/stupid? Yeah i'm doing that...alot!
Fuel lines were opposite way round on the fuel rail. The fuel pump wiring was earthing out too. So add those to the damaged injector driver on the Megasquirt and there we have it!
They're gonna do an oil and filter change and run it round the block to make sure its all ok.
Easy mistake to make,you live and learn!
speed
Postby speed » Sat Dec 10, 2016 7:29 am
I would never had guessed the fuel lines as you had not mentioned removing them.
Am glad you've got it sorted though.
Postby 93_Clubman » Sat Dec 10, 2016 9:24 am
Yeah, great to hear it's fixed!
hoodedreeper
Postby hoodedreeper » Sat Dec 10, 2016 9:26 am
When the injectors got refitted i swapped the fuel rail but thought they were on correctly,oops :oops:
Postby 93_Clubman » Sun Dec 11, 2016 9:00 am
Yeah, better to tell us more than less in these situations.
StanTheMan
Postby StanTheMan » Sun Dec 11, 2016 12:34 pm
Ha ha, I did the same recently. After putting the head back on. On the NA6 they cross over. NA8 they don't
Nice work. .
