SE engine light mystery
jcmx79
Postby jcmx79 » Tue Nov 29, 2016 9:19 am
Hi all, my first post just wondering if anyone has any ideas about my SE.
Have an engine light issue. I'll do my best to explain......
Under load after about 5k revs sometimes the engine would miss and the engine light would come on.
Then after I turned off the car say overnight the light would go out.
So I put new NGK plugs, leads and coils.
Started it no light on all good.
Next day took for a drive and light stays on. And it's still on.
Good news is it's running alot better no missing under load.
Mods are CAI, Exhaust, intercooler, bov.
170km's on the clock.
Checked under the hood nothing seems obvious.
Can anyone help?
Thanks
Sent from my SM-G925I using Tapatalk
ManiacLachy
Re: SE engine light mystery
Postby ManiacLachy » Tue Nov 29, 2016 10:16 am
You need to check the code thrown to learn more. You'll need an ODB2 reader of some description, you can get bluetooth ones fairly cheaply that work with an app on your phone, or take it to a dealer/mechanic.
Postby bruce » Tue Nov 29, 2016 10:37 am
Like Lachy said, this can't be solved over the net. It's not something obvious. Needs someone to look at it.
Postby 93_Clubman » Tue Nov 29, 2016 12:00 pm
Check levels of oils & fluids to eliminate the obvious. Also check for loose or faulty fuel cap, which can cause engine check light to come on.
But as already indicated above, the fault code/s stored in the ECU need to be identified. Depending on your expertise, you may want to leave this to a mechanic with the required equipment. If you want to have a go, disconnect the battery (& pump the brake pedal a few times) to clear all stored code/s, as some may no longer be relevant. Then try to replicate engine check light conditions, & check ECU for code/s with a OBDII code reader, & compare code/s against the NB8 SE code list.
Roadrunner
coyotes after you
Postby Roadrunner » Tue Nov 29, 2016 4:34 pm
SE on factory ECU with CAI and Exhaust at 5000rpm?
My guess would be boost cut. Have you upped the boost and do you have a boost gauge?
$20 ebay scanner will tell you everything.
MeepMeep
jcmx79
Postby jcmx79 » Tue Nov 29, 2016 4:41 pm
Thanks for the advice. Any ideas where the obd2 is? This doesn't look like 1. Image
jcmx79
Postby jcmx79 » Tue Nov 29, 2016 4:42 pm
Got a boost gauge. Haven't changed the boost still stock stops at 7psi.
Roadrunner
coyotes after you
Postby Roadrunner » Tue Nov 29, 2016 4:50 pm
OBD port is above your right knee in the cabin in front of the fuses.
MeepMeep
jcmx79
Postby jcmx79 » Thu Dec 01, 2016 7:08 am
Thanks all. Coil A open circuit. I'll nut it out on the weekend.
Postby 93_Clubman » Thu Dec 01, 2016 9:29 am
jcmx79
Postby jcmx79 » Mon Dec 05, 2016 10:17 am
Update....coil packs making the cel come on. Put the old one's back on hasn't come back.
Postby Okibi » Mon Dec 05, 2016 11:41 am
Are they new factory coils or something after market?
jcmx79
Postby jcmx79 » Mon Dec 05, 2016 2:32 pm
They were ngk.
jcmx79
Postby jcmx79 » Mon Dec 05, 2016 2:38 pm
Users browsing this forum: No registered users and 259 guests
