Anyone run nitrogen in their tyres?
For all those who swear by inflating their tyres with nitrogen, I came across a video on this topic on YouTube.
Quite interesting.
https://www.youtube.com/watch?v=bCnWvMleVD0
Quite interesting.
- Vehicle: Non MX-5
Re: Anyone run nitrogen in their tyres?
Love the way the presenter delivers his message.
Yup. Good one.
I had one of the sales gains at a large tyre chain once tell me "Nitrogen is the standard now, and by next year it will be required by law". Obviously never went back there again.
- smy0003
project.r.racing wrote:Love the way the presenter delivers his message.
I genuinely wondered if the presenter was you.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- Vehicle: Non MX-5
While I can be blunt. I don't think I'm that funny though.smy0003 wrote:project.r.racing wrote:Love the way the presenter delivers his message.
- Cus
I always figured that was the case, but was interested to know just how different the heat expansion and total weight differences would be.
Holy ƒü¢k, made my night, thanks boys !
All true. The only reason racers use it is for consistency of pressures from track to track. The moisture in air while minimal can take up a little of their tuning and valuable set up time. It's one less variable to consider.
- smy0003
Danny wrote:All true. The only reason racers use it is for consistency of pressures from track to track. The moisture in air while minimal can take up a little of their tuning and valuable set up time. It's one less variable to consider.
Which racers are you referring to?
If you're using compressed air from a tank at 1000kPa to inflate your tyres at 200kPa, the drop in pressure (slightly offset by expansion in volume) will cause a temperature decrease as the air leaves the compressed tank. This causes the water vapour present in normal air to condense into its liquid state, which can then be separated out using a garden variety moisture filter:
http://www.supercheapauto.com.au/Product/Blackridge-Air-Inline-Water-Trap/340079
So the air you're putting into your tyres is essentially dry.
My main gripe with the nitrogen thing is that there is no way to fill a tyre with 100% nitrogen. When the tyre fitter puts the tyre on the wheel, there is air inside that tyre at 100kPa (14ishPSI, because that's the normal, everyday pressure in which we live). Whether you add air or nitrogen to that doesn't change the fact that there is still normal air in that tyre. The only way to get 100% Nitrogen in a tyre is to take it back to a complete vacuum then fill with nitrogen, which is horrendously impractical as a tyre will break its seal with the wheel if you try to do that.
- Vehicle: Non MX-5
Now with all that money I'm now saving per tyre refill. I can buy a huge rear wing for my FWD car. Downforce!!!
- StanTheMan
just imagione if you kept a bit extra in the glove box.....and keep it for when you have to talk to the coppers.
that's the ticket
that's the ticket
Actually, race wheels like 6UL have 2 valve on opposite sides to allow the tyre to be purged while its flushed with nitrogen, then filled.
the more you know.
NitroDann wrote:Actually, race wheels like 6UL have 2 valve on opposite sides to allow the tyre to be purged while its flushed with nitrogen, then filled.
the more you know.
Actually my Kosei K1s have two valves. I get the most queries about those than I do anything else on my car! I just tell people it's so I don't have to bend over so far to check my tyre pressures. That and it makes my rims more balanced.
- plohl
^also handy when you have the pushy pump on one valve, and can check the pressure on the other...
plohl
plohl
- smy0003
Ahhhhh that makes sense. Don't think your average tyre fitter will be purging like that though, no matter how many valves you have.
