Patchy's Fawlty Towers risk management. Enter at own risk
StanTheMan
Re: Patchy's Fawlty Towers risk management. Enter at own risk
Postby StanTheMan » Sun Nov 13, 2016 4:31 pm
When you connect a jumper from GND to F/P, it bypassses the relays when ignition is switched on. I can definitely hear it.
It's buzzing away happily.
Disconnect the jumper in the diagnostics box and there is no sign of the fuel pump. No short priming or anything when switching on ignition even when it sat overnight.
I'm not sure if I'm supposed to start the car with the fuelpump bypassing the relays. But it didnt work regardless.
StanTheMan
Postby StanTheMan » Sun Nov 13, 2016 4:47 pm
Just read up in it.
It bypasses the AFM not the relays.
Gawd.
Postby manga_blue » Sun Nov 13, 2016 4:52 pm
If you have a timing light then take out all the plugs and get someone else to spin it while you check where the timing mark on the pulley lights up.
Postby 93_Clubman » Sun Nov 13, 2016 4:58 pm
Fuel is pumped only upon cranking, so you won't hear the fuel pump when you just turn the ignition key to ON.
That reminds me, the AFM has a fuel cut so that in a crash fuel cuts when air stops passing through the AFM - have you got the AFM fully setup?
StanTheMan
Postby StanTheMan » Sun Nov 13, 2016 5:21 pm
manga_blue wrote:If you have a timing light then take out all the plugs and get someone else to spin it while you check where the timing mark on the pulley lights up.
No one around will have to wait. The timing has been set up about the same place as before. It was marked.but will check
93_Clubman wrote:Fuel is pumped only upon cranking, so you won't hear the fuel pump when you just turn the ignition key to ON.
Yes I haven't received the Megasquirt yet. I also left the new wide O2 sensor off so if i did have starting issues there would be less chasing & reverting. (It does have an option to send a narrow band signal)
The AFM has been out in the elements although under a plastic sheet on a crate . The electrical connection is on firm 100%
But because it's been outside I'm now a little paranoid. The top has been cracked open and i lost the top about 12 mths ago it's covered with electrical tape. I'm inclined to still look for a new relay . The one under the dash.
They talk about it having 2 coils in the relay on the big forum. http://forum.miata.net/vb/showthread.php?t=245652
I understand the AFM cutting fuel. But don't understand how to fix the issue if that's it.
First though I'll check to make sure I haven't forgotten to take off the plugs on the fuel filter or something.
Tomorrow night is looking good
"Hick" straight Scotch no 5...... :lol:
Couldn't find any beer
StanTheMan
Postby StanTheMan » Sun Nov 13, 2016 7:12 pm
Got a little bored Fuel filter is fine.
Fuel line looks a little dodgy. That will get replaced.
Postby 93_Clubman » Sun Nov 13, 2016 7:17 pm
StanTheMan wrote:I'm inclined to still look for a new relay . The one under the dash.
Agree, it sounds like it's the fuel pump relay, which isn't that common an issue, certainly not as common as the fuel injection relay.
AFM might be an issue, but not necessarily from a fuel cut perspective, that said re AFM fuel cut:
93_Clubman wrote:Garrett's book also points out the if you convert to MAP & remove the AFM you'll need to circumvent a safety feature of the AFM which is designed to cut fuel as soon as no air flow is detected. Circumventing this safety feature requires a jumper between pins FC & E1 in the plug connecting to the AFM
93_Clubman wrote:miata performance handbook by norm garrett shows the following looking from left to right facing the male plug on the afm:
FC = fuel pump lead
E1 = fuel pump ground
E2 = ground
VC = +5 volts
E2 = ground
VS = air flow signal
THAA = air temp signal
by way of confirmation, the male plug on the afm in the diagram shows two ridges at the top & three ridges at the bottom providing oneway fitting. unfortunately no wire colours are mentioned
StanTheMan
Postby StanTheMan » Sun Nov 13, 2016 7:44 pm
this is just a thought.
There was a lot of pressure on that fuel line. Not much fuel came out. But when the pump got activated a shitload came out.
This would mean there is no fuel going back to the tank. It's not moving. It's getting stuck somewhere. Perhaps there is a blockage near the fuel rail?
Ross
Postby Ross » Mon Nov 14, 2016 4:52 pm
Double check your fuel lines in the engine bay, then have :beer: then check again :P
Ross
1990 BRG V-Special, NB Koni sport with King springs, MS-03's
StanTheMan
Postby StanTheMan » Mon Nov 14, 2016 5:59 pm
Ross wrote:Double check your fuel lines in the engine bay, then have :beer: then check again :P
Maybe I should take a pic of how I've connected the lines.
StanTheMan
Postby StanTheMan » Mon Nov 14, 2016 6:09 pm
Right line goes to the front of the fuel rail
Left line connects to the fuel pressure regulator.
smy0003
Postby smy0003 » Mon Nov 14, 2016 6:32 pm
Well that's certainly correct.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Ross
Postby Ross » Mon Nov 14, 2016 6:36 pm
Ok, i'll shut up now :oops:
Ross
StanTheMan
Postby StanTheMan » Mon Nov 14, 2016 6:44 pm
Ross wrote:Ok, i'll shut up now :oops:
Why?
No silly idea is silly in this thread. Some of the idiotic things I've done here in the past.
Who's to say some clown previously didn't change something around.At this stage I still don't know which one of those two is actually the return fuel line. One way to find out I guess is put the car on 4 jacks & follow the line from the fuel filter. And have a beer. That would then be not the return line :mrgreen:
ralt
Postby ralt » Mon Nov 14, 2016 7:47 pm
Hi.
Stan your fuel lines if you have a 1.6 are incorrect. The outlet on the chassis rail at the front connects to the rear and rear to front. Sometimes the experts on here give incorrect advice-sad.
