Clutch master cylinder
seanmx5
Postby seanmx5 » Wed Nov 09, 2016 8:11 pm
Hey guys,
Juse changing both Clutch master and slave cylinders at with a braided line also.
I'm baffled as to how to get the master.c out..
Do I need to loosed or remove any bolts under the dash as well?
Many thanks
seanmx5
Re: Clutch master cylinder
BTW it's an nb8a
jordan.k
Vehicle: NA6 - Turbo
Postby jordan.k » Wed Nov 09, 2016 8:59 pm
Yep there's one bolt under the dash near the clutch pedal,
Not too hard to get at
NA6 Dulux spec
seanmx5
Postby seanmx5 » Wed Nov 09, 2016 9:14 pm
And this bolt threads onto the clutch master?
jordan.k
Postby jordan.k » Wed Nov 09, 2016 11:58 pm
seanmx5 wrote:And this bolt threads onto the clutch master?
Yea it threads onto that stud that's coming through the firewall
NA6 Dulux spec
jordan.k
Postby jordan.k » Thu Nov 10, 2016 4:01 am
jordan.k wrote:Yep there's one nut** under the dash near the clutch pedal,
NA6 Dulux spec
seanmx5
Postby seanmx5 » Thu Nov 10, 2016 5:43 am
Yeah... I can see that there are NUTS but no bolts that would connect and go through the fire wall and into the master Cylinder.
I'll have a look again carefully when I get a chance.
See if I can take a picture too..
Thanks
Postby hks_kansei » Thu Nov 10, 2016 6:48 am
You'll also need to disconnect the pushrod from the clutch pedal before yanking it out.
seanmx5
Postby seanmx5 » Thu Nov 10, 2016 7:15 am
Here's a picture of under the dash...
Is it the one circled?
Can't find any diy''s on YouTube or the net for nb8a.. only na which requires the 2 bolts from engine bay only.
Thanks guys
seanmx5
Postby seanmx5 » Thu Nov 10, 2016 4:47 pm
Thanks guys.... it was certainly that bolt alright!
Cheers..
Users browsing this forum: No registered users and 206 guests
