Hey guys,
Juse changing both Clutch master and slave cylinders at with a braided line also.
I'm baffled as to how to get the master.c out..
Do I need to loosed or remove any bolts under the dash as well?
Many thanks
Clutch master cylinder
Re: Clutch master cylinder
BTW it's an nb8a
- jordan.k
- Vehicle: NA6 - Turbo
Yep there's one bolt under the dash near the clutch pedal,
Not too hard to get at
NA6 Dulux spec
And this bolt threads onto the clutch master?
- jordan.k
seanmx5 wrote:And this bolt threads onto the clutch master?
Yea it threads onto that stud that's coming through the firewall
NA6 Dulux spec
- jordan.k
jordan.k wrote:Yep there's one nut** under the dash near the clutch pedal,
NA6 Dulux spec
Yeah... I can see that there are NUTS but no bolts that would connect and go through the fire wall and into the master Cylinder.
I'll have a look again carefully when I get a chance.
See if I can take a picture too..
Thanks
Thanks
You'll also need to disconnect the pushrod from the clutch pedal before yanking it out.
Here's a picture of under the dash...
Is it the one circled?
Can't find any diy''s on YouTube or the net for nb8a.. only na which requires the 2 bolts from engine bay only.
Thanks guys
Thanks guys
Thanks guys.... it was certainly that bolt alright!
Cheers..
Cheers..
Users browsing this forum: No registered users and 173 guests
