CarMakeRevive- SR20 6speed tube drift mx5
rascal
Re: CarMakeRevive- SR20 6speed tube drift mx5
Postby rascal » Sun Oct 16, 2016 12:57 pm
Awesome fab work.
ohh, except this bit.... really?
Revive mx5 wrote:Image
cookie
Re: RE: Re: CarMakeRevive- SR20 6speed tube drift mx5
Postby cookie » Sun Oct 16, 2016 2:01 pm
rascal wrote:Awesome fab work.
Surely that's in jest. The drift scene is all about pushing limits. This is a pretty standard practise. It's a worry on the street but these with 50psi (cold) won't fall off, simply allows a super ridged sidewall and ability to run baller rims without heaps of power. It also means you can drop the car lower and not hit stuff.
Sent from my SM-G920I using Tapatalk
Postby bruce » Sun Oct 16, 2016 3:16 pm
Those rims make me think of VIPpers.
Postby Jeo » Sun Oct 16, 2016 3:46 pm
Very nicely done mate. Please do keep us posted with the updates.
luzinit
Postby luzinit » Sun Oct 16, 2016 9:10 pm
Insane build!
Where do you build your rims? Lookin at rebuilding mine and redoing the anodising on the lips, wondering if you could share any contacts or tips.
Tony
Revive mx5
Postby Revive mx5 » Tue Oct 18, 2016 12:02 am
luzinit wrote:Insane build!
Wheel lips/barrels
I use WhiteHorseIndustries, they own all of Simmons Wheels old dies and tooling, talk to Craig, you can download their Proforma in PDF, fill it in and email for a quote.
I've used brisbane metal spinners, don't want to go into details but very highly don't recommend them.
I use A Grade Anadising at Ormeau, $40 per outer
Happy to share info
Revive mx5
Postby Revive mx5 » Tue Oct 18, 2016 12:08 am
The side bars are now done
Just need to finish the boxing in under the front legs and some dimple died gussets to hold the hardtop on and inplace.
Will be removing the dummy box and motor in the next few days to start the front end geometry, looking forward to that.
Postby bruce » Tue Oct 18, 2016 1:14 pm
I just rang Whitehorse Industries as they're local. They can make you the biggest barrels you want.
Revive, I'm guessing you're in Sydney?
Revive mx5
Postby Revive mx5 » Tue Oct 18, 2016 8:33 pm
bruce wrote:I just rang Whitehorse Industries as they're local. They can make you the biggest barrels you want.
Nah I'm in Brisbane, if you talk to Craig tell him that "Brett from Brisbane" put you on to him
Revive mx5
Postby Revive mx5 » Fri Oct 21, 2016 8:48 pm
More roll cage gussets, this roof is never coming off, it's now welded on, placed studs in the factory mount holes and welded them to the cage and b pillar supports
B pillars welded and smoothed
Windscreen frame gussets
Rear window gusset
Also finished the mounts for the window nets, so plenty done of late
Revive mx5
Postby Revive mx5 » Sun Oct 23, 2016 10:39 pm
Just test fitting the rear wheels and arms
A.Chen89
Postby A.Chen89 » Mon Oct 24, 2016 11:00 pm
This is amazing, sick fab work!!
beavis
Postby beavis » Wed Oct 26, 2016 10:49 am
From what car is that arm/hub setup you're using in the rear?
plohl
Postby plohl » Wed Oct 26, 2016 12:23 pm
It's all Silva stiff isn't it? Maybe s14/s15
plohl
Revive mx5
Postby Revive mx5 » Fri Oct 28, 2016 10:54 am
beavis wrote:From what car is that arm/hub setup you're using in the rear?
The rear end uses Nissan s15 geometry, z32 300zx alloy knuckles and twin z32 callipers, ones for the handbrake, the front end is based of Nissan s13 silvia control arms and caster arms with AE86 struts, FD Rx7 callipers on Wilwood two piece rotors
