Bear's White NB8B Turbo "Snowie"
speed
Re: Bear's White NB8B Turbo "Snowie"
Postby speed » Fri Sep 23, 2016 8:47 am
Richard, I really like it. Looks like I will have to chop my frame just like you and davekmoore have.
Postby bruce » Fri Sep 23, 2016 12:05 pm
I sorta thought the first vent was supposed to be vertical, to act as a gurney flap?
What's the underside of the bonnet look like? Just like Dave's?
bear2230
Postby bear2230 » Fri Sep 23, 2016 12:46 pm
Support bracing was cut away with a 4" disc grinder then hand filed smooth.
Vents were painted separately then its just a matter of bending by hand the curve of the grill so it sits nice and flush.(Hellaflush)
A bead if the 3M all around and place into position. It sets in 10 mins and is on forever.
Postby bruce » Fri Sep 23, 2016 4:48 pm
Thanks for the pics. A nice neat job. That 3M stuff will never fail.
I've seen an article on the web, you could cut the vents directly into the hood and bend those up. You'd want a steady hand to cut them neat.
speed
Re: RE: Re: Bear's White NB8B Turbo "Snowie"
Postby speed » Fri Sep 23, 2016 6:35 pm
bruce wrote:Thanks for the pics. A nice neat job. That 3M stuff will never fail.
I suspect that the part where the outer skin meets the frame would be a pain and cutting the frame without the outer skin wouldn't be fun either.
billybunter
Postby billybunter » Fri Sep 23, 2016 11:53 pm
my paint project is nearly over and the possibility of a car sale looks slim - I like the look of these bonnet vents. where do you get them and if you don't mind telling what do they roughly cost to buy and did you keep your cardboard template :lol:
ive never cut into a bonnet before. done a bit of other stuff...but the bonnet never :roll: but if it comes to the crunch a car with 300hp should be able to VENT! :lol: I might give mine the chance
thanks in advance
davekmoore
Postby davekmoore » Sat Sep 24, 2016 8:21 am
http://www.good-win-racing.com/Mazda-Pe ... -1522.html
Stick-on template included.
Other suppliers exist.
The pic is for NA. They also do NB and NC specific ones.
Mine came without Gurney flaps too.
billybunter
Postby billybunter » Sat Sep 24, 2016 11:29 am
thanks for the info. template being included I think would certainly helps solve a lot of guess work :wink:
Postby bruce » Sat Sep 24, 2016 11:42 am
Those vents look good on an NB, especially black on black. The look on an NA doesn't really suit.
bear2230
Postby bear2230 » Sat Sep 24, 2016 1:56 pm
billybunter wrote:my paint project is nearly over and the possibility of a car sale looks slim - I like the look of these bonnet vents. where do you get them and if you don't mind telling what do they roughly cost to buy and did you keep your cardboard template :lol:
thanks in advance
I have a cad drawing of the vents and will Laser cut some within the next couple of weeks. That was one of the reasons I bought them in the first place. I don't need a vented bonnet but wanted a go at making one.
If they come out good I will get the template copied as well by a sign writer I know.
The American
Postby The American » Sat Sep 24, 2016 2:10 pm
Do I smell a group buy? :-)
speed
Postby speed » Sat Sep 24, 2016 2:15 pm
Richard, I'd be keen on a set.
Steve
A.Chen89
Postby A.Chen89 » Sun Sep 25, 2016 2:53 pm
Looking good Richard! Any issues with it parked in the rain?
bear2230
Postby bear2230 » Sun Sep 25, 2016 5:34 pm
A.Chen89 wrote:Looking good Richard! Any issues with it parked in the rain?
Yep, it would leak straight down onto all the belts and alternator as well as some electrics.
My Garage Vary bonnet has a rain rail which I bought separately for about $120. To make these rain proof I think I would need to make up some fibre glass pieces to take the rain away. This would of course decrease the cooling dramatically and kind of defeat the purpose.
You could stick it on your car and use as an everyday bonnet and it would probably be fine as long as it didn't p#ss down and you were parked outside all day.
I think it's more a sunny day thing, pretty much like a MX5 anyway.
Do this to your spare bonnet and change over when you need to. Only takes 10 mins to swap over by yourself.
IanR
Postby IanR » Mon Sep 26, 2016 12:21 pm
Looks great, so much better without the rivets.
I made a little rain scoop things that reduces water onto the alternator, but that did I've dríven my car several thousand ks now in all weather with my vented bonnet... No dramas.
I think what you have done with the vents is the gold standard.
3 different turbo NB's in this single Garage Thread...viewtopic.php?f=57&t=67687
