Been a bit busy last few weekends haven't had a good chance to update. But a fair bit has happened:
So that thing about not painting the engine bay... Sorry couldn't help myself. Colour of choice was Honda Championship White with a 2K clearcoat over the top to seal it in. Quick hit with some scotchbrite pads and a good wipe down and mask up, turned out a lot better than i expected
Before and after
The wiring is coming along slowly, doing an almost full custom engine loom. Only things that it doesnt include is the TPS really. Water temp, temp guage, COP and injector wiring all gone into one easy to access 12 pin Deustch plug.
So now onto the engine, shes been sitting around a while now and after the bay was all painted it finally made its way into the car.
Auto+ lightweight B6 flywheel, DCS heavy duty pressure plate and Excedy organic disk all bolted and torqued to spec.
A little annoying thing I didn't notice till recently is that my sump plug has been previously helicoiled... Which doesn't bother me too much, but my magnet sump plug doesn't sit up nicely against it. Will have to find a special washer so it seals properly :\
Somehow managed to throw the box on with my tiny little arms (Thanks for the help Zabinskii). There;s actually more to this box than i first thought. The previous owner had actually bolted what we think was a FC RX7 input housing onto it because the new throw out bearing didn't slide over it. Odd, but luckily i have spares lying around.
And with lots of cardboard protecting my nice fresh paint we slotted her in back home and called it a day. That was about 3 weeks ago and not a single other bolt has gone back in since then
My fuel pressure regulator system I thought was quite ingenious (probably not really though). Bought a Works Engineering rising rate reg, 1/8 to 1/8 npt union, subaru/toyota 40mm reg adapter and a pressure gauge. Slapped it all together and fits absolutely beautifully.
