Hi guys
I've bought an engine from 2000 MX5. Im told it is a 1.8
can some of you knowledgeable people answer the following
* Is it a 1.8?
* does it have VVT?
* power output?
* Would this be a good track engine, eg free reving?
Engine ID help
- Vehicle: MX5 Locost
Engine ID help
- smy0003
Re: Engine ID help
Yes, no, and it'd be a servjcible track engine if it's healthy.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Re: Engine ID help
just under 100KM on it.
I know the Ks are not ideal
for track.
I'm building a budget clubman track car
Re: Engine ID help
It's a BP4W 1.8l engine from a 1998-2000 NB8A. It's not as powerful out of the box as a later VVT NB8B engine but it is very easy to modify as a track engine. It's a popular choice for track cars.
- smy0003
Re: Engine ID help
Just under 100k kms is pretty good going for a 16 year old engioldne. Plenty of laps left in it.
Do you mean an mx5 na8 clubman or a lotus 7 type clubman.
Re: Engine ID help
- StanTheMan
Re: Engine ID help
GR124 wrote:Hi guys
* Is it a 1.8? Yes
* does it have VVT? No
* power output? 104 Killer wasps at crank
Free revving? anything can be made that way. but as standard? Prolly not as free revving as an NA6 engine. but if you are considering tracking it.....may as well make it free revving. But significantly more powerful than the 1.6 block.
Re: Engine ID help
Thank you StanTheMan and others for their response, it sounds like this engine will be a good fit for my purpose.
Re: Engine ID help
All the above.
I'd be doing he head gasket while it's out, since its easy, and who knows how long the previous owner had he engine running with the rad split.
Re: Engine ID help
hks_kansei wrote:All the above.
good pick up, I'll look into that, Thanks
- StanTheMan
Re: Engine ID help
GR124 wrote:hks_kansei wrote:All the above.
Also check for bent pulleys etc on he front, not hard to replace, but annoying to track down just the pulleys without having to buy the alternator etc they're attached to.
Basically have a look and see if the impact caused anything to be pushed into the front of the engine e.
