Phantom rattles in my NB
speed
Re: Phantom rattles in my NB
Postby speed » Fri Jul 01, 2016 9:50 am
Ed, did you end up sorting it out?
ED_MX5
Postby ED_MX5 » Fri Aug 26, 2016 7:07 pm
Speed,
Nah I hadn't had the time really to do anything with it.
Then when I did drive it, it broke and hasn't run since. On the home stretch now. Car will run again and then I can concentrate on the noise.
-PRAISE THE LOWERED-
Postby Hammer » Sat Aug 27, 2016 1:01 am
It could be the brake pads. I was told, the NB has floating pads [or rather they are loose within their holder and this is by design]. Unlike in the NAs, where they have some sort of spring to stop this. In the NB, when they don't have any pressure on it, they tend to rattle when hitting potholes or on very rough roads etc.
To determine this, drive the car on the same stretch of road that causes the rattles, but this time pressing the brakes slightly to put some pressure on it. If the rattle stops, then it's the floating/loose pads.
Trackphotos
Postby Trackphotos » Sat Aug 27, 2016 10:54 am
NBs have an M spring putting outward pressure on both pads. They don't rattle if the spring is in place, and hasn't been bent badly enough to stop being effective.
Sent from my E6653 using Tapatalk
ED_MX5
Postby ED_MX5 » Sat Aug 27, 2016 1:47 pm
They are some very valid points there.
When my car is back I'll left foot brake it and see how it sounds.
Thanks for the idea :D
Coji
Postby Coji » Thu Sep 15, 2016 4:35 pm
Might be obvious, but have you check the spare tyre is bolted down tightly? This happened to me recently.
ED_MX5
Postby ED_MX5 » Thu Sep 15, 2016 5:19 pm
Good suggestion, but no it wasn't that
