Headlight wiring for mk2 to mk2.5 upgrade
Crazyassdrummerboy
Postby Crazyassdrummerboy » Thu Aug 25, 2016 4:02 pm
Hey there first post here!
I was just wondering whether anyone has successfully managed to have their high beams AND low beams on at the same time after a NB1 to NB2 front end conversion. Most threads just use a simple H4 to HB3/HB4 adapter which means the low and high just alternate.
I came up with this wiring diagram but not 100% sure if it would work correctly.
Any of you guys on here able to confirm that this would work? Or do I need to add/change anything?
Cheers!
Locutus
Re: Headlight wiring for mk2 to mk2.5 upgrade
Postby Locutus » Thu Aug 25, 2016 10:20 pm
You've shorted the low and high beam inputs together so you can't have one on without the other?
Crazyassdrummerboy
Postby Crazyassdrummerboy » Fri Aug 26, 2016 12:28 am
I figured by having the high input run to the low relay it would always run all 4 lights, but when lows are on the highs remain off until switch activated
What I don't get about the diagram you posted is the 2 power inputs to the high beam bulbs. Would that work with a HB4 bulb?
Locutus
Postby Locutus » Fri Aug 26, 2016 3:17 pm
You've joined them so they will both turn on when either is on. Electricity flows both ways along a conductor.
In my diagram, just ignore the bits you don't need.
Or in your diagram, rather than joining terminals 85 together, join terminal 87 of the high beam relay to terminal 85 of the low beam relay.
Or get the work done by an auto electrician so your car doesn't catch on fire.
Crazyassdrummerboy
Postby Crazyassdrummerboy » Fri Aug 26, 2016 3:36 pm
So the only change I needed to make was have 2 lines out from the High beam relay 87 port
Auto electricians want in excess of $150 for this and I like the ability to make my own components
Postby Magpie » Fri Aug 26, 2016 3:57 pm
I would suggest a diode on each of the "green" wires (from 85 and 87), however may not be practical depending on the amps of the circuit.
Crazyassdrummerboy
Postby Crazyassdrummerboy » Fri Aug 26, 2016 5:43 pm
In an ideal world it would have been simple like this for each side harness
but the voltage drop would affect the output too much
Locutus
Postby Locutus » Sat Aug 27, 2016 12:56 pm
Crazyassdrummerboy wrote:NBconversionwiringV3.jpg
This should work just fine.
