It's the first bit towards the MSPnP2......
I think that's the one to get?
Innit?
This Tps was fitted to Patchy on its past tune.
But don't get exited Head shave is next.
hks_kansei wrote:Alcohol doesn't play nicely with some materials, like some rubbers and metals.
Injectors not rated for alco use an have issues with seals degrading (dry out and split etc) when used with alco.
Same as using regular old rubber hose with fuel, will work for a while but eventually will just go crap and melt/split (of course, fuel rates hosing won't do this)
StanTheMan wrote:It's the first bit towards the MSPnP2......
Innit?
Cus wrote:
Re: injectors: If you're getting new ones, get actual new technology ones. datfreak's build thread has links to ones that are cheap, good and wonderful ev14 ones, probably overkill for the car as it sits now, but will also probably be all the injector you'll ever need right up to moderate boost on e85, and better than the old tech from a decade or more ago.
