Alex 2550 wrote: Dann can
Hahahaha you've coined it, and forever it shall be named.
speed wrote:Looking good. Especially liked the wastegate actuator mounting and its location.
I'd like to see a pic of the entire engine bay so I could take it all in
See below
Ok so now I have a few questions. Does the Na8 require a hose from the IAC to the TB intercooler pipe? If so I'd like to see that too.
It does, I'll try and get a pic of that but it hides under the TB intercooler pipe and upper rad hose.
Is that your BOV mounted between the hotside intercooler pipe and air filter?
Yep, it's the one that I bought in a big box of bits from Juffa which included the Mani/Dump and Wideband, no idea what it is but it seems to do the job. Bit of a weird place to put it when you look at it on the bench like that, but it hides it away nicely sort of upright next to the rad on the hot-side when fitted.
Lastly, t25 or t28 and how do you find the spool up and power band now with all the other work that Dann has done?
Well I still don't know for sure. The part number matches a Garret 2554R, but it was a Nissan built (Japan) turbo and Dann said it looked tiny with the compressor housing removed, smaller than a 2554R. It's quite possible that it's from a Skyline GTR (Twin turbo, so has to be tiny), but it's definitely ball bearing as it made 170-180hp on wastegate pressure and you can hear it spin for about 30-40 seconds after you shut the car down. It ran out of puff at 205whp with the EBC, but it suits what I wanted perfectly. I mostly putt about town to work and the shops, and it gets to full boost at half throttle according to my logs. I haven't floored it yet, not even close. So it's good that the little turbo can give me the boost without me having to really stick my foot in it, I'm a bit of a Grandma.
So wish mine was closer to complete.. but one day
It's worth the wait.
