Supercharged NA8 Dyno
Any laptimes and Dyno results that you want recorded.
beavis
Postby beavis » Tue Aug 16, 2016 10:41 pm
NA8 clubman
VVT motor
6spd
4.1 torsen
MP62 supercharger
RX8 injectors
140rwkw or 180rwhp
180-190nm torques
Video:
https://youtu.be/hKrLNZGpsQQ
mk
Re: Supercharged NA8 Dyno
Postby mk » Sun Aug 21, 2016 9:04 pm
what boost is it running
must be allot of fun
beavis
Postby beavis » Mon Aug 22, 2016 11:59 am
It ran about 13psi peak boost.
Since the dyno run, i've since installed a set of ebay headers i had lying around, but installed the stock rear muffler to quieten it down.
And, i've upped the crank pulley diameter so that it now has closer to 15 psi peak boost.
Next step in the plan is to get it running on an MS3.
beavis
Postby beavis » Mon Aug 22, 2016 12:00 pm
And yes it is good fun, particularly in the country or moutain roads.
Not so fun in traffic, or in the wet, or on the freeway.
Return to “Laptimes and Dyno Results”
