how to wire up a variable auto tb on a na6
Technical Guides primarily to do with the NA series
mk
Postby mk » Sun Aug 14, 2016 8:33 am
I was wondering if anyone knows how to wire in a automatic throttle body ( variable ) tps to a na6 with a on/off tps
ill be using a haltech 1000
thanks Peter
Re: how to wire up a variable auto tb on a na6
Postby hks_kansei » Sun Aug 14, 2016 9:15 am
If you're using an aftermarket ecu shouldn't it be as simple as just wiring whatever tps you have into the ecu and then doing the calibration on the ecu?
Postby Magpie » Sun Aug 14, 2016 12:39 pm
http://www.haltech.com/wp-content/uploads/2011/01/Platinum1000WiringDiagramrevJ.pdf
Or by automatic throttle body do you want a drive by wire throttle body?
mk
Postby mk » Sun Aug 14, 2016 3:32 pm
Sorry for not telling the full story
I purchased a auto tb off a 92 mx5 na6
I'll be runing the plug in haltech
Postby Magpie » Sun Aug 14, 2016 4:56 pm
Aaaah a throttle body off a MX5 NA6 that was an auto...
You will need a suitable TPS.
Have you decided how it will be tuned?
speed
Postby speed » Thu Aug 18, 2016 6:42 pm
He's talking about wiring the variable tps from an auto mx5 into his non variable tps on his manual na6.
Isn't it just 3 wires?
Cus
Postby Cus » Fri Aug 19, 2016 4:48 am
If the plug fits, it might just be a matter of calibrating it in the ECU.
I used a VL Commodore one modified with instructions found in the Megasquirt Owner's Thread, it was easier than trying to find an auto TB + TPS.
speed
Postby speed » Fri Aug 19, 2016 9:13 am
Peter, do you have the plug and play haltech yet?
Like others have suggested, maybe you just need to calibrate it.
That's all I did with my MS2.
mk
Postby mk » Sun Aug 21, 2016 10:01 am
ill be purchasing the haltech next week
the plug on the auto tps is a 4 wire and plug is bigger
manual tps has 3 wire and a smaller plug
auto has green/black red/black red green/red
manual has green/white black/white red
Cus
Postby Cus » Mon Aug 22, 2016 8:46 pm
Here you go!
http://www.miataturbo.net/megasquirt-18/how-wire-analog-tps-ms-90-93-car-36271/
Option "B" would be to find a VL Commodore TPS and modify that - it uses the same plug so you're not hacking up the loom on the car.
speed
Postby speed » Mon Aug 22, 2016 9:24 pm
Good work Cus.
From that thread it appears the op has a Na8 tps and not a na6 one. So the red wire is not used.
Since the plug has to be changed it may well be worthwhile pricing a vl commode one that just plugs in.
Cus
Postby Cus » Mon Aug 22, 2016 9:42 pm
As far as pricing a VL TPS, do the legwork to visit local wreckers, the ebay options are priced about $80- $120 more than they need to be!
Return to “NA [1989 - 1997]”
