What inlet manifold - GTX/GTR engine?
- Eeyore
When doing a GTX/GTR Familia engine conversion can you use the NA inlet manifold? I seem to recall the heads being similar. I have seen people cut and modify the FWD Familia manifolds but this seems less that ideal.
Kurt
1971 1300 Estate Deluxe
1973 1300 Wagon
1979 RX7
1973 1300 Wagon
1979 RX7
Re: What inlet manifold - GTX/GTR engine?
If it's the BP-05 head which I think it is then yes the NA8 Intake will bolt right on.
- Vehicle: Non MX-5
NA8 will bolt straight on. The only different between a BP-05 and BP-26 head is some small bumps in the intake ports.
Use the nb8b/c manifold flows the best rather than the na8/nb8a
- Vehicle: Non MX-5
NB manifolds wont work as the flanges on the manifold are different.
Intake is easily available. I found more expense in the oil pickup/pan. Not relevant to this question but something I went through. Also need to block off/ weld the heater core pipe thingo near the thermostat housing. I squashed and brazed mine. I have tried Un successfully to pull it out.
Sent from my SM-G920I using Tapatalk
- Eeyore
What difficulties did you come across? Can't I just use an NA sump and pickup when doing the swap?
Kurt
1973 1300 Wagon
1979 RX7
1973 1300 Wagon
1979 RX7
