NA8 or NB8A: which manifold would you use?
Postby manga_blue » Mon Aug 08, 2016 11:59 pm
Which is the better manifold? I can't decide which one to use. :? :? :?
The decision should really come down to which one is going to perform best in a motor being built for strong mid-range torque in a car that lives in the steep and winding roads between the South Coast, the Southern Tablelands and the Alps. Power is needed most from 3,000 to 5,000rpm. Specs include NB8B pistons, stock NB cams and lifters, mildly ported head, long 4-2-1 headers, tunable ECU, 91 fuel.
I'm setting up an NB8A head right now. It's pleading me to bolt a manifold on and throw it on the car. I have NA8 and NB8A manifolds sitting beside it on the bench, as well as an adaptor flange that lets me bolt the NA8 manifold direct to the NB8A head. I've had no luck finding an NB8B flat top manifold.
The NA8 manifold is in better shape and is much much easier to fit, despite some detail issues.
The NB8A manifold is rougher and is missing a couple of bits (NB fuel rail and VICS solenoid). I may also need to swap the ECU or at least install an RPM switch to activate VICS, assuming it's worth the effort.
Re: NA8 or NB8A: which manifold would you use?
Postby NitroDann » Tue Aug 09, 2016 6:38 am
Flat top.
sailaholic
Postby sailaholic » Tue Aug 09, 2016 7:18 am
Flat top -> Na8 -> nba / Vics
Why all that effort and still running 91?
davekmoore
Postby davekmoore » Tue Aug 09, 2016 8:26 am
Get one of NitroDann's. With a 2860 and a 3" exhaust attached.
Postby NitroDann » Tue Aug 09, 2016 8:46 am
Inlet dave :mrgreen:
Postby 93_Clubman » Tue Aug 09, 2016 3:10 pm
Flat top -> NB8A -> NA8
greenMachine
Postby greenMachine » Tue Aug 09, 2016 4:26 pm
So what is so magical about the flat top - other than it being a handy place to rest tools ... ?
Postby manga_blue » Tue Aug 09, 2016 6:33 pm
Well then, it looks like it will be the NA8 manifold, which is good because it's easier anyway. There's a bit of a drought for flat tops these days. Thanks for the replies.
sailaholic wrote:Why all that effort and still running 91?
98 is easy if you live in the city or along one of the major highways. Out here in the southern boonies the supply of 98 is problematical. It's 20-40% dearer than 91, not many servos carry it, it's often stale or the tank's empty. Don't ask me about E85 either. It would take me more than a full tank to drive to the nearest E85 bowser and back home again. :lol:
sailaholic
Postby sailaholic » Tue Aug 09, 2016 6:54 pm
Fair enough, I thought atleast 95 would have been reasonably available.
E85, yeah I can't be bothered and I live in the city!
Postby 93_Clubman » Wed Aug 10, 2016 11:06 am
greenMachine wrote:So what is so magical about the flat top?
From a quick look side by off motor a while ago, more free plenum volume.
StanTheMan
Postby StanTheMan » Wed Aug 10, 2016 12:28 pm
would someone mind educating the uneducated?
Whats a flat top?
I'm picturing a Morris Minor with a wooden tray.
Postby 93_Clubman » Wed Aug 10, 2016 12:32 pm
It's the ADM NB8B intake manifold - all the US racers want/used to want them.
Postby manga_blue » Wed Aug 10, 2016 1:24 pm
StanTheMan wrote:would someone mind educating the uneducated?
Whats a flat top?
You're not that far off the mark. Didn't the earliest Minors have a flat top motor? :D
Postby manga_blue » Wed Aug 10, 2016 2:04 pm
Yep, life was so simple once.
sailaholic
Postby sailaholic » Wed Aug 10, 2016 2:15 pm
The flat top has the been found to have the best flow from a stock manifold, then the NA8 then the NBA. The Vics did help oem torque but caused alot of turbulence that hurts power compared to the other two.
