NB valve cover sealant
RS2000
Postby RS2000 » Sat Jul 23, 2016 9:33 pm
When installing valve cover (with a new gasket), the Mazda manual says to use sealant just in the corners of the 'half moon' caps.
However, my Gregory's manual says to also apply sealant right around groove in the cover before pushing in gasket.
Have people found the groove sealant necessary?
bigdog
King of the kennel
Re: NB valve cover sealant
Postby bigdog » Sat Jul 23, 2016 10:26 pm
Just in the corners as per the manual.
Sent from my iPad using Tapatalk
Postby hks_kansei » Sat Jul 23, 2016 10:47 pm
Just the corners.
Covering the whole lot is only really for reusing gaskets, or for the old fashioned cork gaskets.
If you do it all around you'll hateyourself next time you need to change the gasket and spend an hour picking the rtv out.
RS2000
Postby RS2000 » Sun Jul 24, 2016 8:50 am
hks_kansei wrote:If you do it all around you'll hateyourself next time you need to change the gasket and spend an hour picking the rtv out.
That's what I was thinking. Thanks hks & bigdog
project.r.racing
Postby project.r.racing » Sun Jul 24, 2016 9:44 am
It is up to you how you do it. I've seen some Mazda factory manuals state to do the whole way round like the Gregory's. And every 4 years they bring out a new manual and someone has changed the way of doing it. Corners at a minimum, the rest is up to you.
Users browsing this forum: No registered users and 36 guests
