Probably a simple question, but car audio isn't my thing.
Have a 99 NB, oem stereo (proper late 90s setup, tape deck, 6disc stacker in the boot)
Being an NB it has the factory electric antennae, which raises when the stereo is turned on, and lowers when then the stereo is off (or when you switch to a non-radio function like tape, or CD)
Anyway, while i'm happy with the OEM gear, the CD stacker skips like mad over bumps, thanks to being in the boot, and also since I have moderately stiff suspension.
I've got a Sony stereo sitting around given to me by a mate, which has an in-dash cd player, which hopefully wont skip as much since it's not directly above a damn axle.
Anyway, when you wire in a non-factory stereo do you keep the electric antennae? or am I going to have to run some wires to a manual switch?
Also, I assume AM radio still works no issue on aftermarket head units? they dont need a separate antennae for that like home systems do they? (asking since the Clarion unit in my daily cant pick up AM clearly at all, and I can't tell why since FM is no problem)
edit:
New unit is a Sony CDX GT180 if there's model differences in the antennae bit.
Aftermarket radio and electric antennae
- KevGoat
Re: Aftermarket radio and electric antennae
Easiest way to fit is to purchase an ISO wiring harness with the correct plug for the car. Then just solder the wires from this to the plug supplied with the head unit. The antenna wire is included. This way you don't damage the original wiring or plug. Ebay sells the harnesses or try Jaycar or Supercheap.
I was going to go the iso route to avoid cutting off the oem plug.
Also need to buy a plug for the Sony head unit (its missing) it looks like Sony plugs are easily available at suoercheap, just hoping that Sony used the same plug for most models.....
So do the iso plugs retail all the factory features like antenna, dim with lights etc?
- smy0003
Depends on the unit. Both my JVC units raised and lowered the antenae properly properly (only up when radio is on) but my Sony unit doesn't (antennae up when unit is on). The JVCs and Sonys are the same plug, well most of them are.
I've got a Sony plug that I've cut the iso connector off that you're welcome to. I've also got the iso plug that I cut off. I was going to wire the Sony plug in before I realised that the jvc unit in there already used the same plug.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- KevGoat
I've managed to replace a Pioneer head unit plug from Supercheap before, but might need to order if not held in stock.
Another option is if you can find a harness that is ISO to your specific head unit (has head unit plug one end), then you don't have to do any wiring at all. So you then have one harness which is the OEM plug adapter to ISO male, then another harness that is ISO female to head unit.
[quote="KevGoat]
Another option is if you can find a harness that is ISO to your specific head unit (has head unit plug one end), then you don't have to do any wiring at all. So you then have one harness which is the OEM plug adapter to ISO male, then another harness that is ISO female to head unit.[/quote]
That's basically my intention, least fuss and I don't need to utilise my questionable wiring skills.
For future reference.
There's no ISO to Mazda plug for the 99 NB (well, none listed in the catalogue at Autobarn/SUpercheap for the Aerpro brand they sell)
looks like they only make them for the later cars (Mazda3, NC, etc.... maybe NB8B if it's the same plug as those)
So yeah, old fashioned hack and splice time.
- smy0003
They are available from ebay, same as the 90's 323's etc.
Hack and splice is quicker considering usual ebay delivery times.
hks_kansei wrote:Anyway, while i'm happy with the OEM gear, the CD stacker skips like mad over bumps, thanks to being in the boot, and also since I have moderately stiff suspension.
If you mount the stacker so the discs are vertical rather than horizontal, it skips 10000% less..
rascal wrote:hks_kansei wrote:Anyway, while i'm happy with the OEM gear, the CD stacker skips like mad over bumps, thanks to being in the boot, and also since I have moderately stiff suspension.
I tried that originally, but still slipped a lot.
I suspect it's mostly to do with the coilovers, since my old stacker skipped a fair bit too (mounted vertically) with my previous softer suspension.
The stacker will live on though, it may end up in my partner's NA6 if she wants it, or more likely i'll setup the old head unit/stacker etc as a garage stereo.
All installed.
Sounds fine, doesn't skip, and electric antenna works like stock ( Only up on radio, select CD and it drops)
Ended up cutting the factory plug off and soldering the new Head unit one on.
The old stereo will likely end up mounted into a box and setup as a garage stereo.
- KevGoat
Good stuff!
The working of the electric antenna can depend on the head unit. I've always had a preference towards Pioneer HU's, but this has meant that I have to put up with the antenna signal being sent as soon as the HU powers up irrespective of what is selected. In my SE I fitted a switch to stop it going up. Other HU's only send the signal when Radio is selected so the antenna stays down rest of the time.
I assumed it would be like yours, and even had a switch ready to wire in.
But yeah, once I tested it it worked how I wanted so I left he switch out. All together.
Users browsing this forum: No registered users and 152 guests
