Replacement NBa engine Rebuld or replace?
simie2014
Postby simie2014 » Wed Jul 06, 2016 8:40 pm
Hi guys, seems my 2000 NBa has a cracked piston. My mechanic says it is terminal.
Rebuild existing engine or put in an engine from a wreck. That is my choice. Looking for a cost effective solution. Any thoughts? Have any of you done either and what was you experience. Cheaper to rebuild? I will have no hands on at all. Cheers. Simon
project.r.racing
Re: Replacement NBa engine Rebuld or replace?
Postby project.r.racing » Wed Jul 06, 2016 9:42 pm
Rebuilds will cost more.
Low mileage engine are out there to buy. Just make sure you know the history of the engine.
bear2230
Postby bear2230 » Wed Jul 06, 2016 10:52 pm
David Gates has a 90,000km for sale on FB
https://www.facebook.com/groups/7326770 ... =562344079
I don't know the guy but looked OK
Richard.
simie2014
Postby simie2014 » Thu Jul 07, 2016 10:12 am
Having trouble finding David Gates facebook link Richard. Can you suggest another way of contacting him?
Postby manga_blue » Thu Jul 07, 2016 10:22 am
Keep the whole head and inlet system if you do swap the engine, don't scrap it. There are often people on the forum looking for one to upgrade an NA8.
noobee
Postby noobee » Thu Jul 07, 2016 6:42 pm
simie2014 wrote:Having trouble finding David Gates facebook link Richard. Can you suggest another way of contacting him?
I believe this would be the one.(when posts are previewed,the links get truncated for some reason)
https://www.facebook.com/groups/7326770 ... 9112323263
If forced induction is on the menu,rebuilding with stronger components is better but expensive,otherwise for normal use a lower kilometer used engine is the go.when we pulled my son Ken's (90,000k) VVT engine apart for strengthening everything measured up within new tolerances,it was almost shame to pull good parts out.
If there's not too much collateral damage from piston debris I'm interested in purchasing a cheap engine that suits rebuild (at my leisure though. I'm mostly retired so labour is free!)
Mick
simie2014
Postby simie2014 » Fri Jul 08, 2016 2:15 am
Thanks for the lead mate. Ill check it out.
Users browsing this forum: No registered users and 22 guests
