15x8 185/55/15 after some pics? Tyre & tein talk.
- Learner Driver
- Vehicle: NA6 - Turbo
Hey guys just did a little upgrade to wheels and suspension, went from 16's to 15x8 +17 all round and they came with a 45 profile but its not giving me desired ride and appearance. Also I paired it with a new set of Tein flex coilovers which has result in a ride hight of about 50mm and still mile of space between the tyre and fender.
Im not chasing epic stance, rather I would like to be able to get in and out of my driveway without the planks of wood. Hence I'm after some pictures of a 55 profile or bigger!
I've seen plenty of 50 profile on the wheels thread but only 1 of a 55 seeing as not many people put up the details of the tyres!
Looking for a bit more side wall to compensate for some of the ride height, feel and I also like the look of a fuller tyer
Also if anyone has tein flex coilovers what damper settings do you like to run? Looking for a bit of feedback on what is a good balance for spirited weekend driving more than general day to day duties as its a weekender.
Thanks in advance!
Thanks in advance!
- StanTheMan
Re: 15x8 185/55/15 after some pics? Tyre & tein talk.
Let me get this right.
You want to put a 185 tyre on an 8 inch rim?
- Learner Driver
Yeah, its what it has on there now and its fairly minimal stretch of the tyre wall. You'd think with a lager wall it would further reduce that. I dont see the big deal.
- smy0003
205/50.
Yokohama has a 4 for 3 sale on currently and Bridgestone do regular sales also.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- Learner Driver
Thanks for the tip mate but I've seen plenty on 50 profile. Im after info on some 55's or or 60.
185 tyre would fit on a 6" rim max. If you're using an 8" rim, you should be on a 225 tyre.
But hey...if you want to wear jeans that are two sizes too small, no one is going to stop you.
- davekmoore
Is it April 1st?
- KevGoat
'Ol days we use to go widest on a rim ... nowadays it's thinnest ... trends ...
Sent from Samsung S7 using Tapatalk
- Learner Driver
People really cant look past the first number hey? Let me word it differently as to not confuse. It currently has 185/45 (I know, dont have a panic attack) and seeing as these didnt come accross as ridiculously streched in my opinion I thought a 55 profile would further reduce this. Hey maybe a slightly wider tyre will work in my application but that's why i put the question to the mx5 community. I'm trying to maintain a fitment where I wouldn't have to pump the fenders but merely lip them mildly.
I've seen plenty of 205/50's and information on them is quite common but thanks for your input.
205/50 has a taller sidewall than 185/55. 102.5 mm vs 101.75 mm.
It's a lot easier to find 205/50 tyres in a compound and tread pattern to suit an MX5 than it is to find 185s. 185/55 tyres on our market are mostly (all?) shyte.
- Learner Driver
Thats actual helpful information, thank you. Im just looking for some tyre info to replace the current one with some that fit more correctly.
I also notice the quality of this size of tyre when I had a hunt around but I'm not looking for a cheap solution.
- smy0003
If you're struggling to get the wheels to fit, sell them to a Honda owner and buy some that do.
I'd like to see a photo of what you consider to be 'not stretched.'
- aka_juffa
https://www.google.com.au/search?q=185/ ... B7QQsAQIKg
and
https://tyrestretch.com/8.0-185-45-R15/
and
https://tyrestretch.com/8.0-185-55-R15/
The above tyre/rim combination don't look as streched as one might have expected....i.e.
and
and
- Vehicle: Non MX-5
If you want more sidewall. You will need some 185/70R15 light truck tyres. 185/55 is not bigger than 205/50.
- 1600Dave
manga_blue wrote:205/50 has a taller sidewall than 185/55. 102.5 mm vs 101.75 mm.
Yep, the 50/55/60/etc profile is a percentage of the width rather than an actual measurement.
So as tyre width increases, so does sidewall height even though the profile stays the same.
Users browsing this forum: No registered users and 117 guests
