15x8 185/55/15 after some pics? Tyre & tein talk.
LittleRed5
Vehicle: NA6 - Turbo
Postby LittleRed5 » Tue Jul 05, 2016 9:43 pm
Hey guys just did a little upgrade to wheels and suspension, went from 16's to 15x8 +17 all round and they came with a 45 profile but its not giving me desired ride and appearance. Also I paired it with a new set of Tein flex coilovers which has result in a ride hight of about 50mm and still mile of space between the tyre and fender.
Im not chasing epic stance, rather I would like to be able to get in and out of my driveway without the planks of wood. Hence I'm after some pictures of a 55 profile or bigger!
I've seen plenty of 50 profile on the wheels thread but only 1 of a 55 seeing as not many people put up the details of the tyres!
Looking for a bit more side wall to compensate for some of the ride height, feel and I also like the look of a fuller tyer
Also if anyone has tein flex coilovers what damper settings do you like to run? Looking for a bit of feedback on what is a good balance for spirited weekend driving more than general day to day duties as its a weekender.
Thanks in advance!
StanTheMan
Re: 15x8 185/55/15 after some pics? Tyre & tein talk.
Postby StanTheMan » Tue Jul 05, 2016 9:48 pm
Let me get this right.
You want to put a 185 tyre on an 8 inch rim?
LittleRed5
Postby LittleRed5 » Tue Jul 05, 2016 9:56 pm
Yeah, its what it has on there now and its fairly minimal stretch of the tyre wall. You'd think with a lager wall it would further reduce that. I dont see the big deal.
smy0003
Postby smy0003 » Tue Jul 05, 2016 10:00 pm
205/50.
Yokohama has a 4 for 3 sale on currently and Bridgestone do regular sales also.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
LittleRed5
Postby LittleRed5 » Tue Jul 05, 2016 10:05 pm
Thanks for the tip mate but I've seen plenty on 50 profile. Im after info on some 55's or or 60.
Apu
Postby Apu » Tue Jul 05, 2016 10:06 pm
185 tyre would fit on a 6" rim max. If you're using an 8" rim, you should be on a 225 tyre.
But hey...if you want to wear jeans that are two sizes too small, no one is going to stop you.
davekmoore
Postby davekmoore » Tue Jul 05, 2016 10:16 pm
Is it April 1st?
Postby KevGoat » Tue Jul 05, 2016 10:18 pm
'Ol days we use to go widest on a rim ... nowadays it's thinnest ... trends ...
Sent from Samsung S7 using Tapatalk
LittleRed5
Postby LittleRed5 » Tue Jul 05, 2016 10:29 pm
People really cant look past the first number hey? Let me word it differently as to not confuse. It currently has 185/45 (I know, dont have a panic attack) and seeing as these didnt come accross as ridiculously streched in my opinion I thought a 55 profile would further reduce this. Hey maybe a slightly wider tyre will work in my application but that's why i put the question to the mx5 community. I'm trying to maintain a fitment where I wouldn't have to pump the fenders but merely lip them mildly.
I've seen plenty of 205/50's and information on them is quite common but thanks for your input.
Postby manga_blue » Tue Jul 05, 2016 10:32 pm
205/50 has a taller sidewall than 185/55. 102.5 mm vs 101.75 mm.
It's a lot easier to find 205/50 tyres in a compound and tread pattern to suit an MX5 than it is to find 185s. 185/55 tyres on our market are mostly (all?) shyte.
LittleRed5
Postby LittleRed5 » Tue Jul 05, 2016 10:39 pm
Thats actual helpful information, thank you. Im just looking for some tyre info to replace the current one with some that fit more correctly.
I also notice the quality of this size of tyre when I had a hunt around but I'm not looking for a cheap solution.
smy0003
Postby smy0003 » Tue Jul 05, 2016 10:49 pm
If you're struggling to get the wheels to fit, sell them to a Honda owner and buy some that do.
I'd like to see a photo of what you consider to be 'not stretched.'
aka_juffa
Postby aka_juffa » Wed Jul 06, 2016 2:26 pm
https://www.google.com.au/search?q=185/ ... B7QQsAQIKg
and
https://tyrestretch.com/8.0-185-45-R15/
and
https://tyrestretch.com/8.0-185-55-R15/
The above tyre/rim combination don't look as streched as one might have expected....i.e.
project.r.racing
Postby project.r.racing » Wed Jul 06, 2016 3:00 pm
If you want more sidewall. You will need some 185/70R15 light truck tyres. 185/55 is not bigger than 205/50.
1600Dave
Postby 1600Dave » Wed Jul 06, 2016 3:33 pm
manga_blue wrote:205/50 has a taller sidewall than 185/55. 102.5 mm vs 101.75 mm.
Yep, the 50/55/60/etc profile is a percentage of the width rather than an actual measurement.
So as tyre width increases, so does sidewall height even though the profile stays the same.
Users browsing this forum: Bing [Bot] and 2 guests
