Bear's White NB8B Turbo "Snowie"
tomli123001
Re: Bear's White NB8B Turbo "Snowie"
Postby tomli123001 » Mon Jul 04, 2016 3:55 pm
bear2230 wrote:I was never really happy with the Pod filter so I asked Dann to come up with something that would flow better and was also a legal option for the replacement of the SP Carbon Fibre box we all love so much. :roll:
So this was the result and I think it worked out really well.
While modifying the inlet we discovered the piping was not quite up to scratch so Dann put pipe beads on all the intercooler and inlet piping. :D :D
This is one of those things that you should just do properly the first time or it will bite your arse at the worst possible moment.
He also remade and moved the BOV plumbing further down, polished the tubing and generally cleaned it all up.
Finally a huge alloy air box was designed and installed finishing off the whole engine bay nicely except for the front strut brace.
Thank you very much Dann. Its a pleasure to work with someone with this kind of knowledge and passion. :beer: :beer: :beer:
Can I please ask what oil filter you use in the above photos? They look larger than an OEM Mazda unit and almost twice as big as the K&N unit I have on the car right now.
NA6-Rolled off Mt Nebo
NB SE-Sold for investment property deposit, then crashed by the buyer months later
Now Black NB SP #31.
Postby Okibi » Mon Jul 04, 2016 7:26 pm
tomli123001 wrote:
bear2230 wrote:...
bear2230
Postby bear2230 » Tue Jul 05, 2016 9:02 am
Ive now gone black and I can't go back. Its no bigger though than the white one…….So that's one Myth Busted :D :D
Richard.
bear2230
Postby bear2230 » Wed Aug 17, 2016 11:58 pm
So started playing with one of my 4 bonnets (don't ask) and finally did the cut outs for the bonnet vents.
It took about 2 hours all up with a cordless drill and a jigsaw and then some hand finishing with a smooth file and a 12mm round file.
Hardest part was getting the template in the right place.
It will be painted gloss black to match the white hardtop that is getting painted gloss black. I wasn't happy with the colour match on the hard top, so will go back to black after originally swapping my black one with Danny. It seemed a good idea at the time. Wifey says it was another one of my Harris hair brain ideas. :( :(. Harsh….
At least It will match the vented bonnet.
Im not using the rivets supplied as it will look sh*t but I have some 3m Scotch-Weld 8805. Its a 2 pack adhesive that sets in 5 mins. I will glue it on and file the edge of the bonnet with a 45 chamfer. Should look nice but we will see.
I am also getting one of the other bonnets painted white as I accadently ruined my good white one :oops: :oops:
One day they will probably be for sale as a matching pair as well as the Garage Vary carbon fibre bonnet. One day.
ManiacLachy
Engaged
Postby ManiacLachy » Thu Aug 18, 2016 7:55 am
I'm expressing an early EOI on the Garage Vary, should that day arrive please let me know.
speed
Postby speed » Thu Aug 18, 2016 8:59 am
Four bonnets.. wow!
But with all the crap I have, I can't talk.
Look forward to seeing the finished product :)
Nevyn72
Postby Nevyn72 » Thu Aug 18, 2016 1:39 pm
ManiacLachy wrote:I'm expressing an early EOI on the Garage Vary, should that day arrive please let me know.
Oi.... I've got dibs on that one! :?
Geez mate, you already gazzumped me on the speed deck. :roll:
Lets see if can find the pm I sent Richard when I missed out on the original sale due to procrastination.......
ManiacLachy
Engaged
Postby ManiacLachy » Thu Aug 18, 2016 2:12 pm
Nevyn72 wrote:Oi.... I've got dibs on that one! :?
Fine! :evil:
But I'm second in line should you pass. I too was very very close to putting down the money when it was up for sale.
speed
Re: RE: Re: Bear's White NB8B Turbo "Snowie"
Postby speed » Thu Aug 18, 2016 2:19 pm
I can see it now.. an appropriate ecu and bits comes up for sale just before Richard lists the bonnet. Hahaha
bear2230
Postby bear2230 » Thu Aug 18, 2016 3:05 pm
Nev is first. My records are good :D :D :D
Postby Lokiel » Thu Aug 18, 2016 4:18 pm
speed wrote:Four bonnets.. wow!
I think that 4 MX5 bonnets trumps the 7 MX5 seats I had at one time (now down to 5).
Where does Magpie's "eleventy-three" sets of rims+tyres slot in to this scale?
bootz
Postby bootz » Fri Aug 19, 2016 9:05 pm
113? That's more than me
bear2230
Postby bear2230 » Fri Sep 23, 2016 12:15 am
Here the finished bonnet. Also got the hard top painted the same colour (gloss black)
I wasn't going to hold the vents on with those stupid rivets so they are attached using 3M Next Generation Acrylic Adhesive DP8805NS. This stuff is just the best and the bonnet is as rigid as it was before I chopped out the bracing.
Postby Okibi » Fri Sep 23, 2016 12:41 am
Can't wait to see it on the car!
davekmoore
Postby davekmoore » Fri Sep 23, 2016 12:42 am
Good work!
Yes, the pop rivets would be horrible:
Interesting that Singular decided their Gurney flaps were no longer needed.
