NA8squeak from front of engine on starting
My NA8 gets a squeak ,sounding like a dry bush or seal ,when starting from cold . It only lasts 5-10 seconds and appears to come from either the water pump ,PS pump ,ac clutch or alternator. I don't particularly want to go on a drawn out fishing expedition to find it. Has anyone had a similar problem who could point me in the right direction. I've tiied a little CRC without much success,and don't think it's a belt slipping.
- smy0003
Re: NA8squeak from front of engine on starting
Tighten your accessory belts.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Have done that,I think it may have sorted it.They seem to need a bit more tension than I thought.
A worn damper / crank pulley can do that too. The rubber ring between the pulley and hub sections can go bad. Often but not always you can see some wobble at idle.
Users browsing this forum: No registered users and 185 guests
