Have had my share of bad experiences with people in Brisbane. To the point that I no longer bother with most brisbane shops
StanTheMan wrote:Not that I know a real lot about tuning stand alone ECU,
The AFM has a temp sensor in it. But if the afm has been removed you would get a more accurate result if the air temp is installed. a better place for the air temp would perhaps be near the plenum if at all possible.not sure if it would m,ake a massive difference though. i would assume that you would get better drive ability with it installed?
did you open up the air intake? or is it the standard one? Like removed air box & enlarged the intake? I would assume with all the trouble you went though, you would have done that.
