Bucket seat belt mounts
Tigger
Postby Tigger » Sat Jun 25, 2016 9:44 am
Hi all. First topic post!
So, first of all, hi. Read many posts over time, and now I need some info.
I live in Sydney, and have a silver nb8c.
Now the intro is out of the way... I've been looking at bucket seats, and find pretty much none of them have belt mounts on them (that I can see). I use it as a daily, so need the standard seat belts.
Is there a way to legally mount the seat belt lock onto the bucket seat?
Thanks!
rascal
Re: Bucket seat belt mounts
Postby rascal » Sat Jun 25, 2016 9:57 am
Just mount the seatbelt stalk to the transmission tunnel.
I have a six point harness in mine with a sparco seat and mounted the orig stalk to the tunnel to enable me to keep the std belts for when it goes on the road..
Tigger
Postby Tigger » Sat Jun 25, 2016 10:15 am
Thanks rascal. Does that pass pink slip?
Dan
Postby Dan » Sat Jun 25, 2016 12:00 pm
I had seat belt mounting points installed into the fixed side mount of my seats.
Doubt they'd pick up on either mounting method for a pink slip if it was done properly.
Postby hks_kansei » Sat Jun 25, 2016 12:09 pm
Ask the RTA.
Simplest way to get he answer, ask the ones who will be deciding what is and isn't legal.
I've got mine on the trans tunnel like rascal, big spreader place etc.
It's safe, but in Vic isn't legal unless I get an engineer to provide me with a report for vicroads.
Postby 93_Clubman » Sat Jun 25, 2016 12:13 pm
Tigger
Postby Tigger » Sat Jun 25, 2016 8:07 pm
Thanks clubman. Clearly I as searching for the wrong words.
So turret is fine as long as there is a backing plate to spread the load.
greenMachine
Postby greenMachine » Sat Jun 25, 2016 10:11 pm
Use your stock rails?
I assume the seat itself is ADR compliant?
:mrgreen:
Tigger
Postby Tigger » Sat Jun 25, 2016 11:20 pm
Yeah it is. I find the stock rails are a bit high, but if they fit and work, can defo use them in he meantime.
DTH
Postby DTH » Thu Aug 11, 2016 6:35 am
Hi guys, both passenger & i have an issue with the shoulder strap on our 98 NB8A biting into our neck. Surely there's a better solution than the woolly sleeve on the belt? Suggestions appreciated.
