Last Friday of the Month Mt Nebo/Mt Glorious Night Run
Queensland Events
Moderators: timk, Andrew, miata, AJ
SKYHI
Re: Last Friday of the Month Mt Nebo/Mt Glorious Night Run
Postby SKYHI » Fri May 27, 2016 1:54 pm
zero00 wrote: TCR - is the SE Velocity Red and named 'LioNeL'? Notice the caps :wink:
Ah, just got it :) Yes, that's the one.
joshuam
Postby joshuam » Fri May 27, 2016 2:03 pm
I have the lamest excuse ever.... I think I'll just be sitting at home alone, with a working car, because I went out and played basketball with some mates for a couple of hours last night without having the right sports shoes and ended up with massive blisters on the balls of my feet and toes and it hurts to walk / drive :P
'00 Midnight Blue NB8B - 4.1 Torsen 2 | Tein Flex-Z | Enkei RP01 :)
Garage Thread: Here
Novice1
Postby Novice1 » Fri May 27, 2016 3:35 pm
i am out.
been sick last two days.
novice1
mattyredlocks
Postby mattyredlocks » Fri May 27, 2016 7:05 pm
Guys please. C'moooon.
Because reasons.
MattyRedlocks' MX-5: Moxxi the NB (Currently running, and properly for once!)
slyfox2151
Postby slyfox2151 » Fri May 27, 2016 8:08 pm
Omw... be there at 735
slyfox2151
Postby slyfox2151 » Fri May 27, 2016 8:36 pm
Well... im here by myself... hope others are coming?
Steampunk
Postby Steampunk » Sat May 28, 2016 3:47 am
Great night guys.
Passed tow truck about to pull out a Golf GTi-R that took the term "tree hugger" too much to heart.
Managed to pick up a stray Alfa Romeo Mito tagger-a-longer.
slug dub almost had a close encounter of the turd kind with an Evo driver coming the opposite way who thought that straddling the centre line is the place to be.
Can confirm 100% there are no 80 signs at all. Pretty annoying now as 70 is quite pedestrian.
MattR
Postby MattR » Mon May 30, 2016 2:27 am
Andrew, from the description of the night you wonder why the road is now 70???
Unfortunately Idiocracy becomes closer to a documentary every day.
I hear modified shitters go up the hill, 30 minutes later I hear sirens heading up the hill. I here very expensive flat plane crank euro exotics head up the hill, I here them come down again, no sirens, says something about the owners i think.....
Trackphotos
Postby Trackphotos » Mon May 30, 2016 9:38 am
It's a pretty safe bet that if they were running into trees and couldn't keep on their own side of the road, ignoring a 70kmh speed limit isn't any better than ignoring an 80kmh limit, don't you think?
Steampunk
Postby Steampunk » Mon May 30, 2016 2:32 pm
EVO was in middle of the road on a moderate lefty curve for it, righty for us, and appeared not to be speeding (not by much if it was). Simply a sh!t driver.
Golf came off where the road had very mild bends, relatively straight, and after a flat crest so he (2 guys no older than 25) either had a tyre blow or other failure, and/or panic swerved to avoid wildlife, and/or significantly speeding.
Besides putting speed humps, there's nothing that will stop idiots speeding.
Even after we finished when we were on a very narrow section down in The Gap (due to 1/4 of the road cut away) amongst houses and doing the signed 40 in an obvious construction zone with copious debris on the road, some sh!t heel in a 3 series BMW came blasting past doing well over 70.
phoe
Postby phoe » Thu Jun 23, 2016 2:56 pm
Anyone :?:
Phoe
mattyredlocks
Postby mattyredlocks » Thu Jun 23, 2016 3:34 pm
Entirely possible.
Because reasons.
phoe
Postby phoe » Thu Jun 23, 2016 4:07 pm
So, you have consulted the magic 8 ball.
Phoe
mattyredlocks
Postby mattyredlocks » Thu Jun 23, 2016 4:16 pm
All signs point to yes.
Because reasons.
Steampunk
Postby Steampunk » Fri Jun 24, 2016 2:28 pm
Going, I am. Some testing, I need to do.
Return to “Queensland”
Users browsing this forum: No registered users and 119 guests
