davekmoore wrote:Do you reckon there'd be any advantage from finding the right kind of heat shield to go on the turbo side to maybe reduce air temps going to the filter?
IanR wrote:I'm definitely redoing it now!!!! Thanks for the inspiration, just have to figure out where to get there engine mount kit for the LS motor![]()
NitroDann wrote:You -used- to be able to use the rally tracks if you shut your trap about it, which was farking sweet when I ran some rally cars.
Nevyn72 wrote:Then you head over to your local bank manager and offer up your first born as a deposit.......
