Looking to find someone that has put 16x8 et20 on a nb8b
cherrymx5
Postby cherrymx5 » Tue May 17, 2016 12:28 am
Hopefully i find someone, want to know what it takes to fit
Thanks
This was my 15x8 et0 with no arch work just too big
cherrymx5
Re: Looking to find someone that has put 16x8 et20 on a nb8b
Postby cherrymx5 » Tue May 17, 2016 9:28 pm
Surely someone?
bear2230
Postby bear2230 » Tue May 17, 2016 10:59 pm
Here you go champ.
Plenty more here as well
viewforum.php?f=30
cherrymx5
Postby cherrymx5 » Wed May 18, 2016 7:11 am
What arch work did you have to do?
bear2230
Postby bear2230 » Wed May 18, 2016 11:54 am
Guard rolling front for sure and maybe rear as well depending on how low you want to go. That extra inch makes all the difference :oops: :oops:
http://sydneyguardrolling.com.au/
Nelson is a expert and I highly recommend.
and1
Postby and1 » Wed May 18, 2016 10:38 pm
I've answered your question last time in one of your threads:
http://mx5cartalk.com/forum/viewtopic.php?f=30&t=71501
15x8, +20 with 205/50/R15 with need a slight roll of the fender lip if you are moderately low. 16s in the same size with CORRECT sized tyres (read 205/45) with fit the same.
ImageDSC_0111 by An Phan, on Flickr
2005 Velocity Red MX-5 SE
Garage thread
cherrymx5
Postby cherrymx5 » Thu May 19, 2016 10:36 pm
Did you have any camber? People talk about natural camber gain..
My wheels are straight as in zero camber and on shocks and springs, so I can't go lower. I want the look you have, just scared of being outside my front fender yet again and being defect noticed..again
The look you have is perfect though.. Spot on
Sorry for the repeat question
and1
Postby and1 » Sat May 21, 2016 9:56 pm
You will gain negative camber as you lower the car naturally. It normally has a positive effect on the handling characteristics of the car. That is as long as everything is dialled in accordingly as well.
To be honest I really don't know what the alignment specs are at the moment. I haven't had it aligned for a while, but there is a little bit of neg camber on the wheels.
cherrymx5 wrote:Did you have any camber? People talk about natural camber gain..
Garage thread
mx5002
Postby mx5002 » Tue Jun 07, 2016 12:04 pm
That's 16x8.25 +15 so it's 8mm wider than what your talking about. I have - 3 camber on the front and rear
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
Harrisk
Postby Harrisk » Sun Jun 12, 2016 3:59 am
16x8 +15 on 205/45
cherrymx5
Postby cherrymx5 » Sun Jun 12, 2016 9:52 pm
mx5002 wrote:Image
Are these a staggered fitment?
mx5002
Postby mx5002 » Tue Jun 14, 2016 9:24 am
No same specs all round.
If you have a look in garage chat. Corey's Nb journal. I think his first set of wheels were the same specs that your asking about too
GREEN ITB'd NB8B
Marulan 47.01
Postby Regie » Sun Jun 19, 2016 12:22 pm
my old NB with MS03s 16x8 +32 with 20mm spacers. So +12 offset in the pic
cherrymx5
Postby cherrymx5 » Thu Jul 14, 2016 1:25 am
All sorted 16x8+20 cheers for the info and pics
smy0003
Postby smy0003 » Thu Jul 14, 2016 9:48 am
Looks great. About as far as I'd go without it being obvious cop bait.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Users browsing this forum: No registered users and 110 guests
