Adaptronic launch control and flat foot shifting
Re: Adaptronic launch control and flat foot shifting
hi, yeah i checked the inputs today, both 1 and 2 are clutch (act low), so I'm not really sure why its not working
Welcome to cars.
- Learner Driver
You could try and see if the clutch switch is working in the f11 window
If only you could call a customer service rep for your ecu.
Cough. Andy. Cough.
Cough. Andy. Cough.
Or ask directly on the adaptronic forum.
There's a reason adaptronic doesn't have phone numbers listed and that's because they can give better support via email.
Hi Thanks everyone for your help, i contacted the adaptronic support on Tuesday, turns out the adaptronic launch control has nothing to do with the clutch, you just need to set it and accelerate and it should work, they did a test of my map on there bench ecu and the launch control worked fine for them, though I'm going to test it again tomorrow and if its still not working ill just need to get the log and send it in to them.
thanks again
thanks again
I got it working, so just in case anyone else wants to set this up, here is how it's done, just check the launch control, step on the throttle and your done
Initially I thought it had to do with the clutch, so I was pushing the clutch down and only slightly pushing the the throttle down, because that's what I had seen with the Megasquirt
So this time I just set it up, and pushed the throttle down the whole way and it worked. Who would have thought, anyway thanks again everyone for help
