Uneven Height
kingjooz
Uneven Height
Postby kingjooz » Wed Apr 13, 2016 4:40 pm
I've got an NA6 with Koni Yellows with lowered king springs. However the driver side sits about 10-15mm lower than the passenger side.
I did a physical check on the shocks, no leaks visible around the shocks itself, however ive noticed that the springs on the driver side (front & rear) are more compressed than the passenger side (front and rear), hence the uneven height.
Not sure why this is happening. Any help or advice would be much appreciated.
Thanks!!
Re: Uneven Height
Postby Magpie » Wed Apr 13, 2016 5:10 pm
Do the springs have any numbers on them?
Does the drivers side sit lower with or without the driver in the car?
Re: Uneven Height
Postby 93_Clubman » Thu Apr 14, 2016 12:40 pm
