185kw turbo built na6 engine -what do I need?
speed
Postby speed » Mon Apr 04, 2016 7:29 pm
Hi all,
So I've decide to go turbo and have the following.
Begi exhaust manifold.
T28 turbo.
Sump with oil return.
Water and oil lines.
Eagle H beam forged rods. (Came with forged pistons but 2 are scored)
Dump pipe.
Rx8 injectors.
Toyota COPS.
Nitrodann coolant reroute.
MS2.
Yet to source a tube and fin cooler and make my own alloy piping.
Apparently I'd need to run 16psi at 6,000rpm to get 185kw atw.
Will be paying to have the head and block machined and head assembled with new valve stem seals etc.
Crank will also be machined.
Questions below:
1.Before I do this, should I be going for an increase in piston size and what compression are people running?
The forged pistons are 8.5 but should I go higher or lower. Some people have said that even stock 9.5 pistons would be adequate but I'm not so sure and don't want to skimp on the bottom end.
2. What bearings should I use?
3. Do I need to remove a lug to run water cooling for the turbo?
4. Would regular rebuild gaskets suit or do I need something special?
5. Including injectors; how much would an e85 set up cost me (parts)?
I.thought I'd be able to achieve my goal on 98 but would be good to know.
What have I missed?
Thank you very much,
Steve
1green5
Re: 185kw turbo built na6 engine -what do I need?
Postby 1green5 » Mon Apr 04, 2016 11:31 pm
speed wrote:What have I missed?
Cost of repairing/upgrading gearbox, differential and associated components.
Postby Okibi » Mon Apr 04, 2016 11:41 pm
ManiacLachy
Engaged
Postby ManiacLachy » Tue Apr 05, 2016 7:53 am
Clutch upgrade? Or are you already running something stronger than stock?
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Tue Apr 05, 2016 8:20 am
You could just install a V6. 185kw's and no turbo.
Postby NitroDann » Tue Apr 05, 2016 9:16 am
speed wrote:Hi all,
T28 turbo.
Dump pipe.
Rx8 injectors.
Toyota COPS.
MS2.
Questions below:
Stock to 9 ish on 98, stock pistons and rings are fine if healthy
OEM is fine.
Forget the water cooling. But if you absolutely feel the need check the miataturbo wiki
OEM
You can easily, if you want to.run united every day just fit a walbro 255 intank for 170 and id725 for 800
What have I missed?
Steve
speed
Re: RE: Re: 185kw turbo built na6 engine -what do I need?
Postby speed » Tue Apr 05, 2016 9:23 am
Okibi wrote:5. an off the shelf solution https://www.flyinmiata.com/fm-nb-big-flex-fuel-kit.html
Will check that out right now. Thankyou!
lightyear wrote:You could just install a V6. 185kw's and no turbo.
Really want an engineered turbo 4.
ManiacLachy wrote:Clutch upgrade? Or are you already running something stronger than stock?
Already have an upgraded clutch :)
Already have a 4.1 torsen. The gearbox is a weak link but I'm a very simpathetic driver.
Is the engine stuff that I want to sort out before I arrange machining.
chrons_rotary
Postby chrons_rotary » Tue Apr 05, 2016 10:26 am
Bigger brakes, NA8/NB8A minimum.
Also +1 for the V6.
speed
Postby speed » Tue Apr 05, 2016 11:54 am
chrons_rotary wrote:Bigger brakes, NA8/NB8A minimum.
Also +1 for the V6.
Got those too. Really want engine specs, namely pistons and water line bung.
Postby NitroDann » Tue Apr 05, 2016 12:20 pm
I posted answers to both.
Leave the pistons stock.
Dont run water. If you have to run water the info with pics is in the miata turbo wiki.
chrons_rotary
Postby chrons_rotary » Tue Apr 05, 2016 5:23 pm
speed
Postby speed » Tue Apr 05, 2016 6:16 pm
chrons_rotary wrote:http://miataturbo.wikidot.com/water-lines
Thanks Ken :)
speed
Postby speed » Thu May 05, 2016 8:04 pm
NitroDann wrote:
Questions below:
Sorry Dann, I must have missed this post. Really appreciate your responses.
By 9ish, do you mean 9.0:1 and can I get away with a thick head gasket?
If so any idea how thick?
Also would stock pistons handle 16-20psi if tuned correctly?
Thanks again,
Steve
Postby NitroDann » Thu May 05, 2016 8:39 pm
Stock pistons will go deep into the 300whps
9:1 is fine, Id say just use your original ones and rering if necessary.
speed
Postby speed » Fri May 06, 2016 9:29 am
NitroDann wrote:Stock pistons will go deep into the 300whps
Ok great. Thank you very much.
