BEAVIS' White Track Car
beavis
Re: BEAVIS' White Track Car
Postby beavis » Tue Mar 15, 2016 10:20 pm
Just a quick update.
Trying not to reveal too much of our secrets, but starting to think about a new rear wing...
Postby Magpie » Wed Mar 16, 2016 5:34 am
It is was secret the background should be light blue, for example
speed
Postby speed » Thu Mar 17, 2016 8:12 am
Magpie wrote:It is was secret the background should be light blue, for example
Like a certain winged keel.
beavis
Postby beavis » Sat Mar 19, 2016 12:08 am
A small assortment of things have happened this week...
Bonnet repair/strengthening
So I had a bit of flex in the carbon bonnet where it extended out from the molded mounting section that the hinges bolt to.
I'd long been meaning to fix it. So i finally got around to sorting this out.
Removed the bonnet, gave the areas that need repair a quick sand to scuff them up, then laid down a few layers of some scrap carbon I had.
After the resin in the repair patch had set, I cleaned it up with a grinder, sanded and painted to blend it in.
The flex that used to exist here is now long gone, really happy with the bonnet now
Clutch
In preparation for more of the powers, new clutch has been swapped in. Exedy button ceramic should do the job. These things are actually made just 15mins down the road.
Battery
Thinking about a better spot the put the battery, this might do. Moves the weight to the middle of the car, and the cables are much shorter.
Not 100% convinced this is the best spot to put it. I guess we'll see.
That sound deadener stuff
I was doing something else and got distracted, and suddenly had an impromptu desire to start hacking the sound deadener out of the car with a chisel.
I'll just need to hit it with some paint and it'll be good as new.
davekmoore
Postby davekmoore » Sat Mar 19, 2016 6:39 pm
Heavy stuff, paint.
beavis
Postby beavis » Sat Mar 19, 2016 9:02 pm
Perhaps I should sand the paint off the whole car?
Apu
Postby Apu » Sat Mar 19, 2016 9:22 pm
And rusting wil be part of the passive weight reduction programme
corners
Vehicle: ND - Supercharged
Postby corners » Sun Mar 20, 2016 8:58 am
beavis wrote:Perhaps I should sand the paint off the whole car?
Well GTR N1s have less coats of paint to make them lighter...
d3ck5
Postby d3ck5 » Sun Mar 20, 2016 2:06 pm
did you go 1.6 or 1.8 clutch?
stock flywheel?
speed
Postby speed » Mon Mar 21, 2016 8:46 am
Thanks for the pics re the sound deadening. Did lightyear make your bonnet and ant ideas how I'm best to contact him?
Sent a pm last week but haven't gotten a response yet. Cheers mate :beer:
beavis
Postby beavis » Mon Mar 21, 2016 6:11 pm
d3ck5 wrote:did you go 1.6 or 1.8 clutch?
stock flywheel?
i have had a lightweight ACT flywheel on the car for a few years now.
it is 1.8 size.
beavis
Postby beavis » Mon Mar 21, 2016 6:13 pm
speed wrote:Thanks for the pics re the sound deadening. Did lightyear make your bonnet and ant ideas how I'm best to contact him?
Yeah Lightyear and I made the bonnet on moulds that he had.
speed
Postby speed » Mon Mar 21, 2016 7:01 pm
Sweet. Looks fantastic! He replied to my pm. Seems getting the time is the issue. So he is human just like the rest of us :p
greenltd
Postby greenltd » Sun Mar 27, 2016 9:01 pm
So did A9X torana's
speed
Postby speed » Mon Mar 28, 2016 2:34 pm
In the 60s you could buy drag prepped cars from chrysler that were acid dipped and primed only.
So just pour acid all over her...
Users browsing this forum: No registered users and 121 guests
