beavis wrote:You don't need dry ice to get the sound deadener tar off.
Just use elbow grease and a suitable scarper/chisel/hammer etc
and maybe a bit of heat gun?
3gress wrote:There is a build log on mx5nuts and clubroadster called panda2. The car had some serious weight reduction. For an example the boot latch and rear support stamping was removed along with boot hinges. The frp boot lid was held down with latches. The hole saw was powered up here and there too.
It got fairly extensive with frp doors added along the way. See if you can find the build log, it was in the epic roadsters section of the clubroadster build log forum.
Also search targa miata for inspiration.
These two build were built for racing predominately though there are ideas enough relevant to street cars.
Post no.#100
madjak wrote:
My "making" I really mean grinding. Spend 1 hour on each rear hub with an angle grinder and flapper wheel and you can get off around 300-400 grams in material without any structural loss. Only poblem is cleaning up all the waste filings.
Magpie wrote:Manual winders to replace electric ones.
Remove door cards (use a heat gun on the black goo, when it bubbles wipe it off).
Remove centre console (even easier with manual Windows). OMGPham sells a plate to move the window switches if you retain them and delete centre console.
This interests me but may be above my abilities as I'd be concerned about balancing issues. Is it just the burrs that I'd have to remove? as I could do that, same with brake calipers
3gress wrote: Courtesy of Keith Tanner.
3gress wrote:I'd do it if i could find a decent way of securing it discreetly while still allowing access.
Magpie wrote:3gress wrote: Courtesy of Keith Tanner.
Not a good idea if you have a big wing on the back
