I'm really frustrated.
Todd B wrote:As for the cam sensor, I think what I'm going to do is take mine off, and ask my neighbor if I can put it in his car. If his car won't start, then I know mine is bad.
manga_blue wrote:NB8A engine looms have a reputation for copper failing inside the wire very close to the coil connector plugs.
93_Clubman wrote:Could be the usual NB8A coilpack wiring loom weakness, ie a lack of support to the wiring where it bends near the coilpacks results in wires breaking inside the plastic insulation. To check for this, after a decent drive, with vehicle idling, move the wiring loom in this area - if you get a variation or stumble in idle revs then some of the wiring could be on the way out.
Todd B wrote:One of the things I didn't reassemble...
