MX-5 Club of QLD - Track Day Morgan Park 19th March 2016
Queensland Motorsport
Moderators: timk, miata, Andrew, AJ, JBT
Cal
Re: MX-5 Club of QLD - Track Day Morgan Park 19th March 2016
Postby Cal » Thu Mar 10, 2016 2:11 pm
Car repaired from Gary's off at Lakeside last month. Tail shaft problem rectified, trailer booked and wheel alignment Tuesday. Looking good.
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Thu Mar 10, 2016 6:48 pm
Lookin' better than good! It heartens me that this can be done. Maybe I can worry less myself about damaging my aging ride.
zero00
Postby zero00 » Thu Mar 10, 2016 7:42 pm
Cal wrote:Car repaired from Gary's off at Lakeside last month. Tail shaft problem rectified, trailer booked and wheel alignment Tuesday. Looking good.
Nice work Cal :wink:
Look forward to watching Gary tackle MP
Roger D-SUNSHINE COAST
gslender
Postby gslender » Thu Mar 10, 2016 8:01 pm
ndragun wrote:Real shame, since I want to contribute to making Morgan Park work. Easily the best track 'local' to us.
Yeah, will be a shame if you can't make it. Would have loved to do some runs in front or behind - we're a good match and it makes for a fun day when you've got closely matched cars on such a great track. Hope it works out!
Postby Magpie » Thu Mar 10, 2016 9:13 pm
I was looking forward to seeing another ITB engine!
Cal
Postby Cal » Fri Mar 11, 2016 10:00 am
Red_Bullet wrote:Lookin' better than good! It heartens me that this can be done. Maybe I can worry less myself about damaging my aging ride.
Would you believe the whole repair was under $1000?
zero00 wrote:Nice work Cal :wink:
I'm having a drive this time too. :)
Vat
Postby Vat » Fri Mar 11, 2016 6:08 pm
CAMS license turned up today.
'98 Evo Gold NB8A
zero00
Postby zero00 » Fri Mar 11, 2016 7:07 pm
Vat wrote:CAMS license turned up today.
Yeah I would Cal - I had my NB done maybe a year ago after a vicious and violent letterbox attacked it! I will PM you as to who did the repair and cost - NFP on any website but he will look after any MX-5 owners for those small bingles :wink:
Vat
Postby Vat » Sat Mar 12, 2016 11:30 am
What are people doing about fire extinguisher mounts? I gather the most popular mount is a bit of plate between the passenger seat front mounts. I found an aluminium beam under the glovebox that I managed to mount the extinguisher to (which I can still reach from the driver seat with my belt done up) but I'm concerned that won't be deemed sufficient for scrutineering purposes.
'98 Evo Gold NB8A
Trackphotos
Postby Trackphotos » Sat Mar 12, 2016 3:14 pm
Technically it needs to be mounted securely enough not to move in a 25G impact. Presumably where ever it's mounted, the scrutineers just yank on it and make sure it doesn't move. If that beam moves or bends, which iirc it does pretty easily, it won't be acceptable.
Sent from my E6653 using Tapatalk
Red_Bullet
Postby Red_Bullet » Sat Mar 12, 2016 4:13 pm
I stuck my extinguisher on the front passenger seat mounts and have removed the passenger seat, hopefully no passenger seat will be ok for scrutineering, if not i'll stick the seat back in but would like front seat bolts to be a bit longer with extinguisher in place. Thread engagement is reduced with extinguisher bracket.
Vat
Postby Vat » Sat Mar 12, 2016 4:19 pm
Yeah, saw the 25g requirement and figured that'd be an issue. I of course have one longer bolt that fits the passenger seat bolt hole with the steel plate I was experimenting with. Had considered removing the passenger seat.
Sent from my SM-G920I using Tapatalk
'98 Evo Gold NB8A
Red_Bullet
Postby Red_Bullet » Sat Mar 12, 2016 8:46 pm
Yep, I'll visit Bolt Masters and buy a couple of longer bolts this week on the way home from work. I was lucky that my car came supplied with a steel bracket for extinguisher. I was just a bit shabby so I wire brushed it and repainted.
Postby Magpie » Sat Mar 12, 2016 8:58 pm
Car is back home, spent the week at Plus getting tweaked and adjusted.
Headed up the MCA to discuss suspension, dropped some parts off as well. Busy day!
Getting it ready for Morgan Park, swapping splitter/wheels and getting 'stuff' organised. Should be interesting to load on the trailer as the smaller splitter scrapes now!
slug_dub
Postby slug_dub » Sat Mar 12, 2016 10:43 pm
I am sorted for both days of the weekend, Ruth and I staying overnight Saturday. Hopefully we'll finish the Turbonator in time for me to oil change and put in some front pads before Saturday.
Return to “Queensland”
