Wanting quicker acceleration NC with cosworth Supercharger
Re: Wanting quicker acceleration NC with cosworth Supercharg
Postby NitroDann » Wed Mar 09, 2016 7:00 pm
speed wrote:Just for my limited opinion, what is the 0-100 time now?
I know it's not the best test but would give me something to compare it to.
Thankyou
For interests sakes a lot of the turbo na.nb chassis get into the mid 4s on the street on street tyres.
Novice1
Postby Novice1 » Wed Mar 09, 2016 7:12 pm
Thankyou
I thought friends golf r was quick at 5 secs flat to 100 kph.
Then another friend bought 2016 merc a45, 0-100 4.2 secs. That thing absolutely hammers.
Novice1
Postby NitroDann » Wed Mar 09, 2016 8:29 pm
Only 0-100, it would be womped 50-150 or higher by an MX5 turbo with a stock engine.
Novice1
Postby Novice1 » Wed Mar 09, 2016 10:13 pm
NitroDann wrote:Only 0-100, it would be womped 50-150 or higher by an MX5 turbo with a stock engine.
It would be interesting Dan my old mx5 205 kw atw vs friends merc. Lol.
Novice1
speed
Postby speed » Thu Mar 10, 2016 8:32 am
Thanks Dann, power to weight FTW.
Would that translate to ballpark 12 sec quarters or faster?
Novice, apologies for the highjack but speed, power and weight appear relevant. :)
Dan
Postby Dan » Thu Mar 10, 2016 9:11 am
For reference, it looks like the A45 with just a tune does a 12.28 and has a trap speed of 112mph (180km)
If someone has the trap speed for a stock block turbo MX5 it'd be interesting to compare.
Novice1
Postby Novice1 » Thu Mar 10, 2016 10:17 am
Friend charlies car.
Power to Weight Ratio Engine power divided by vehicle weight 186.7 (W/kg)
Engine CodeEngine code as specified by the manufacturer. M133 Torque The 'pulling power' of a vehicle, measured in Newton metres (Nm) 475Nm @ 2250-5000rpm
Novice1
Postby NitroDann » Thu Mar 10, 2016 10:58 am
Engine torque is not relevant to performance.
Postby Magpie » Thu Mar 10, 2016 12:22 pm
Novice1 come out to Morgan Park next Saturday and give a demonstration :)
Postby bruce » Thu Mar 10, 2016 2:15 pm
Despite what people say, the A45 is one ugry car. A funny looking Benz with bits hanging off. Stock exhaust sounds horrible (echoey drainpipe).
speed
Postby speed » Thu Mar 10, 2016 5:40 pm
bruce wrote:Despite what people say, the A45 is one ugry car. A funny looking Benz with bits hanging off. Stock exhaust sounds horrible (echoey drainpipe).
And it's 85k!
Tony
Postby Tony » Thu Mar 10, 2016 5:50 pm
Dan wrote:If someone has the trap speed for a stock block turbo MX5 it'd be interesting to compare.
I don't wish to hijack Ron's thread, but I can offer some sort of comparison.
Power wise my SE is reasonably standard. The only changes of note are an AEM intake, an axle back exhaust with hot dog (rest of exhaust is standard) and an Adaptronic.
I had a before and after dyno run done when the Adaptronic was installed and it only picked up around 10 RWKW (still plenty of room to improve the tune I guess). What the Adaptronic did however was dramatically improve the driveability. It now has 146 RWKW.
At the Cootamundra airport as part of the Nulon Nationals in 2014, my best time was 13.7 sec @108.9 mph over the quarter. Not sure whether that's good or bad.
'09 NC2
Novice1
Postby Novice1 » Wed Mar 16, 2016 4:54 pm
Ok before and after figures. Disappointed with the dyno figures but not with the butt dyno.
To me car is considerably quicker
Other change in car went up from 205 to 215 size tyres.
Before 8.5-9 psi
Powe 214.6 hp @ 6500 rpm
Torque 433.6 NM @4833 rpm
Air density 98 percent
Correction factor 2.32 SAE J607
Air Temperature 24 degrees
After 11 psi
Power207.2 hp
Torque 419.4@ 5250 rpm
Air density 94.6 percent
Correction factor 5.59 SAE J607
Air temperature 30 degrees
Novice1
speed
Postby speed » Wed Mar 16, 2016 5:41 pm
So no more 6500 RPM?
Would have been good to compare but who cares about numbers, as long as you are happy with what you got for the money :)
Novice1
Postby Novice1 » Wed Mar 16, 2016 6:12 pm
speed wrote:So no more 6500 RPM?
Sorry, yes 207.4 hp @ 6500 rpm
Novice1
Users browsing this forum: No registered users and 225 guests
