That crank is a bloody good piece of steel. It's not a fun job.
Don't cut too much off or you will find the engine starts to chew up big end bearings.
zossy1 wrote:Further to this, and FYI... Balancing the knifed crank is, according to our engine balancer, an absolute bitch of a job. Factor in $$$ above and beyond a normal balancing job.
madjak wrote:there will probably be weeks of back breaking wiring and then debugging.
madjak wrote:I cut out all the holes with a dremel. For anyone copying this, be careful cutting carbon fibre as the dust is nasty. I had my woodworking extractor fan hooked up just above where I was working and it was very effective of sucking up the dust.
