Overtime the clear coat started to peel off my carbon mirrors, but i never got around to fixing them.
Would anyone know what i could do to remove the entire clear coat and repairing the actual carbon?
Cheers.
lightyear wrote:Use a Stanley blade to scrape of the flakey paint. Sand it, and use a decent clear coat.
mr2 spyder wrote:don't sand the carbon if you can help it and just needs enough sanding to get bite / not a shinny surface / fine grade wet and dry is enough.
