Is there anyone in the Brisbane area who is handy with fabricating turbo exhaust manifold heat shields?
Before you ask, yes I've tried DIY but it hasn't turned out very well... EVERYTHING IS MELTING!
I'm running a TD05 Greddy kit (see pictures). It's all quite an awkward shape and lots of things are in the way (mainly heater hoses), hence my failure at self attempt.
Turbo exhaust heat shield fabricators? [BRIS]
- NicTheMx5
NA6 TD05
Re: Turbo exhaust heat shield fabricators? [BRIS]
firstly, get nopro washer bottle and totally remove that from the equation.
have you tried some gold heat tape on those hoses?
what about silicone hoses?
- bear2230
Heat shield material from Ebay and a Turbo blanket made a heap of difference on the white car.
Just a couple of bent brackets to support the cover. Now all the hoses aren't melting
http://www.ebay.com.au/itm/150871392886 ... EBIDX%3AIT
http://www.ebay.com.au/itm/turbo-muffle ... SwPe1UBwUs
Richard.
Richard.
- NicTheMx5
Ebay turbo blanket is holding up ok?
I've heard some pretty bad "fire" related things about even name brand turbo blankets, so I've just stayed away.
Also washer relocation kit is on its way in the mail!
NA6 TD05
- NicTheMx5
NicTheMx5 wrote:Ebay turbo blanket is holding up ok?
Actually also keeping in mind this is a daily driver, so it wouldn't be every second weekend at the track sort of thing either.
So not sure how long they would last in this situation. Anyone have any advice or knowledge on the matter?
NA6 TD05
