Big end bearing failure, fixing and cleaning up afterwards
Re: Big end bearing failure, fixing and cleaning up afterwar
Postby manga_blue » Fri Jan 29, 2016 8:22 pm
It's always good to have a spare engine in the shed for tinkering,
NPR rings, ACL race bearings, maybe Eagle rods, Reinz gaskets, full balance of rods, crank, pistons, harmonic balancer, GMB water pump, machine the lip off the flywheel, check out stronger oil pumps, 50 thou head shave, clean up the ports, unshroud the valves, ... endless employment ☺
1600Dave
Postby 1600Dave » Fri Jan 29, 2016 9:12 pm
Or endless enjoyment :D
1600Dave
Postby 1600Dave » Sat Feb 13, 2016 2:04 pm
All fixed :D
Even treated it to a sexy wrinkle red rocker cover :roll:
Time to start buying bits for the dead engine and rebuild it.
