NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
No...I don't like that you make that exhaust system. It caused me to spend money.
Thanks Dann. Apologies for going off topic..
Do you happen to know the maximum N/A engine size we could legally fit in a na6?
4L by memory
- smy0003
Ford barra swap!
Specific question, but what do you use for vacuum and power sources? Do you use a vacuum block? I can see vacuum lines getting out of hand pretty quickly with bov, wastegate etc etc.
Are you pulling the wideband power from the blue timing light plug behind the passenger headlight? Or have you made a separate cuircut with a relay switched by the radio as described in mt.net?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
FPR+MAP
BOV on its own
EBC on its own
Power EBC and wideband at the ecu.
BOV on its own
EBC on its own
- smy0003
Thanks Dann. Exactly what I needed to know in as few words a possible. Extremely helpful.
Soon
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
They all for the one car? Look good.
Lol
89-05
89-05
- mx5002
The movie Total recall comes to mind???
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64
Marulan 47.01
Wakefield 1.09.64
- Vehicle: ND - RF
NitroDann wrote:Lol
89-05
So a revised version of the catch-can then?
It appears to be a sealed unit unlike my 1st generation version...... How/where is it fitted?
- beavis
- Vehicle: NB8B - Turbo
Shame, they look to small to be up to CAMS spec. Only about 1 litre?
Nevyn its a sealed version of yours.
It comes with a drain tap, and a recirculated version will be available, so its available in a configuration which is road and track legal, and it can easy be installed to automatically drain back.
Users browsing this forum: No registered users and 185 guests
