http://www.carbonmiata.com/index.php?ro ... duct_id=83
Has anyone used one of these? From my understanding, putting a subwoofer in the boot of an MX5 is hardly worth it. This seems like a good product, but I'm wondering about durability and speaker clearance.
It claims you can use 6.5" speakers with a little cutting, but is that cutting the panel, or the car itself? I can't find any 6" subs, only 6.5".
Out of the three materials (fibreglass, carbon fibre, kevlar) available, which one should I get? Chances are I will be putting carpet over it, but I don't want the speakers to cause it to crack or something.
Carbon Miata rear subwoofer panel
- Learner Driver
- Vehicle: ND - Supercharged
- beavis
- Vehicle: NB8B - Turbo
Re: Carbon Miata rear subwoofer panel
I would presume they refer to cutting the panel itself. There appears to be plenty of space between the circle cutouts and the edges.Mind_Reader7 wrote:It claims you can use 6.5" speakers with a little cutting, but is that cutting the panel, or the car itself? I can't find any 6" subs, only 6.5".
Fibreglass would surely more than suffice. Fibreglass will be heavier and weaker than the alternatives, but not enough to cause issues, particularly if you're hiding it with the stock carpet.Mind_Reader7 wrote:Out of the three materials (fibreglass, carbon fibre, kevlar) available, which one should I get? Chances are I will be putting carpet over it, but I don't want the speakers to cause it to crack or something.
- KevGoat
Difficult to see how much mounting depth there is for any sort of decent speaker, especially as the mounts in this panel are recessed.
Looks like some of the original shelf metal has to be cut from the one speaker area. Not sure how this would impact replacing the original panels if putting back to stock later on for whatever reason - but obviously less than actually cutting holes in the deck for speakers
With the amount of bump and impact vibrations that can go through these cars, I'd be a bit concerned about attaching speakers with decent magnets just to this without screwing down into some metal to add support, but that's easy to add something.
Looks like a simple solution to adding some rear speakers though. If I was considering this, I'd go the fibreglass and use the savings to purchase enough Dynamat to cover the back of the panel plus the area beneath ....
- beavis
On second thought, couldn't you just take a jigsaw to the factory metal trim and achieve the same result?
- Learner Driver
The factory aluminium trim is VERY thin and flimsy. I wouldn't want to mount anything to it, let alone a sub.beavis wrote:On second thought, couldn't you just take a jigsaw to the factory metal trim and achieve the same result?
- Learner Driver
Hadn't considered using Dynamat. Cheers for the input. I feel I'll also buy some super thick rubber spacers for the speakers, and trim them down if I have to.KevGoat wrote:Looks like a simple solution to adding some rear speakers though. If I was considering this, I'd go the fibreglass and use the savings to purchase enough Dynamat to cover the back of the panel plus the area beneath ....
- beavis
Mind_Reader7 wrote:The factory aluminium trim is VERY thin and flimsy. I wouldn't want to mount anything to it, let alone a sub.beavis wrote:On second thought, couldn't you just take a jigsaw to the factory metal trim and achieve the same result?
I think it would handle it, its not what I would call 'VERY' thin. Also, I thought it was steel, not aluminium.
I let Carbon Miata know about this thread, they should be able to answer all your questions.
I did have a pair of 8" speakers in my NB parcel shelf but I had to raise the height of the front of the shelf a fraction.
If I had to do it again I think this panel is a much neater solution and saves a lot of hassle.
- Learner Driver
https://www.youtube.com/watch?v=RMt920dBC1gbeavis wrote:I think it would handle it, its not what I would call 'VERY' thin. Also, I thought it was steel, not aluminium.
Around the 16 minute mark, they start playing with the parcel shelf.
- beavis
Around the 16 minute mark, they start playing with the parcel shelf.[/quote]
yes they did....
yes they did....
- Learner Driver
Haha, I meant to imply that it IS very thin. It's bending without the, putting any force on it. Getting a solid one made from fibreglass seems worth it in my book.
Steel is stronger than fibreglass, and also more likely to flex rather than crack.
The stock panels are steel, and should be fine to hold speakers, bumps and all.
Yes, you can bend them easily, but speakers wont be mounted in a way they will put any kind of force in a small enough area to bend.
If you're really concerned just sandwich some MDF behind the speakers to remove any flex.
Either way, i'd see the steel panels as being the better option than the fibreglass. (obviosuly depends on the glass and design)
