Brake Lines for an NA8
BRG.NA8
Postby BRG.NA8 » Mon Jan 04, 2016 11:16 am
Hey all
Im going to be purchasing some goodridge stainless steel braided brake lines.
Just wondering, would these brake lines for an NA8 also fit an NA6, i.e do NA6 and NA8 both have the same brake line hardware and are interchangeable?
Ice88
Re: Brake Lines for an NA8
Postby Ice88 » Mon Jan 04, 2016 11:59 am
Different callipers, same hardline and master. At least from the parts catalogue.
BRG.NA8
Postby BRG.NA8 » Mon Jan 04, 2016 1:07 pm
so although theyre different calipers for the NA6 and NA8, what you're saying is the brake lines will fit both? Even the OEM stuff?
beavis
Postby beavis » Mon Jan 04, 2016 1:31 pm
I'm pretty much 99% sure the calipers are the same NA6 to NA8, BUT the mounting bracket is different, allowing the NA8 to accommodate a larger diameter brake rotor.
Therefore, same brake lines on all NA's.
Postby hks_kansei » Mon Jan 04, 2016 3:45 pm
I know for sure that the NA6 and NA8 use different brake pads, so i'm pretty confident that the calipers are different, at least in regards to the end that faces the rotor.
In saying that, i'm pretty sure they all use the same brake line fittings etc.
beavis
Postby beavis » Mon Jan 04, 2016 6:35 pm
hks_kansei wrote:I know for sure that the NA6 and NA8 use different brake pads, so i'm pretty confident that the calipers are different, at least in regards to the end that faces the rotor.
larger rotor = larger pad?
StillIC
Postby StillIC » Mon Jan 04, 2016 8:46 pm
beavis wrote:I'm pretty much 99% sure the calipers are the same NA6 to NA8, BUT the mounting bracket is different, allowing the NA8 to accommodate a larger diameter brake rotor.
^^^This is correct^^^
hks_kansei wrote:so i'm pretty confident that the calipers are different, at least in regards to the end that faces the rotor.
^^^I think this is incorrect.^^^ Yes, they use different pads because the brackets are different, not because the calipers are different. The pads fit into and slide in the brackets, not the calipers. I know this from accidentally buying NA8 calipers and brackets for my NA6. I only had to replace the brackets to put it back to normal, and for my NA6 pads to fit. So I have NA6 pads in NA6 brackets with NA8 calipers (which are the same as NA6 calipers).
BRG.NA8
Postby BRG.NA8 » Mon Jan 04, 2016 9:36 pm
Thanks everybody! Picked up a set of goodridge braided brake lines.
FYI, these basically fit both NA6 and NA8's as mentioned above!
