Jammed Boot lid. SE
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, zombie, Andrew, -alex, miata, PUR157
jezman
Jammed Boot lid. SE
Postby jezman » Wed Dec 30, 2015 3:02 pm
Help please, boot lid jammed closed.
Will unlock ok with either key, remote or console cable, but won't open !
NRMA can't help, something is jamming the latch.
Any clues please ?
Wakefield. SMSP GP: SMSP South: SMSP North: SMSP Brabham: Baskerville: MX5 heaven ! Symmons Plains: Winton: Sandown. Phillip Island (wow)
pezchops
Re: Jammed Boot lid. SE
Postby pezchops » Wed Dec 30, 2015 6:22 pm
if no one comes up with any ideas you may need to see a panel beater.
im sure they deal with that sort of thing all the time.
Did you Google it?
NA with a jammed boot- a guy used a hole saw to get to the detached connecting rod between the key hole and the latch.
Postby NitroDann » Wed Dec 30, 2015 8:56 pm
If heavy things are in there they are probably against it.
Try slamming the brakes on HARD.
Seriously
davekmoore
Postby davekmoore » Wed Dec 30, 2015 9:04 pm
Yep, and/or find a very steep hill.
Postby KevGoat » Wed Dec 30, 2015 9:53 pm
Maybe try pushing down on the bootlid while unlocking ...
edit: .... ummm ... not while going downhill, slamming the brakes on :shock:
davekmoore
Postby davekmoore » Wed Dec 30, 2015 10:52 pm
All of the above.
All usual disclaimers apply.
jezman
Postby jezman » Thu Dec 31, 2015 9:18 am
Thanks gentlemen for the imaginative ideas :D
Solution was simple in the end..........
Squeezed the thin WD40 tube between the rubber seal and boot lid, gave it 10 minutes and it opened normally.
Note to self: lubricate catch regularly !
Return to “MX5 Technical Guides”
Users browsing this forum: No registered users and 23 guests
