Sideways on ripple strip - damaged chassis?
The Green Goblin
Postby The Green Goblin » Sun Dec 27, 2015 12:35 pm
Hey Gents,
recently attended a WP track day in my 02 NB, long story short - pushed a little too hard & ended up loosing control & going over a ripple strip sideways. my car is not ridiculously low, but low enough to make contact with the raised surface, being the ripple strip.
i have video footage of this but in crappy format that doesn't allow me to edit etc, looking over it - you can definitely hear when impact occurs, it was somewhat violent - in that it moved the camera mount when the car made contact. I also recall looking towards the rear of the car as it was in motion, & seeing sparks fly up when contact was made (although i was packing it, i was also relaxed in a weird sort of way). anyways, when i jacked up the car & got under it this is what i was able to see:
side view
directly underneath
under car, scratched underside & sheared bolt head
these were the only bits of damage i was able to see, there doesn't appear to be any other bent items besides the chassis rail as pictured. after it happened, the car stalled (as i steered it onto grass), had to pull the keys out to turn it on, engine light was on & remained on for a couple of hours. when i drove back to pits, i felt no weird vibrations, steering was not compromised, no weird noises etc.. in other words, there were no structural issues.
should i be worried about this? is this a common occurrence? have i defiled my beloved..?
cheers,
Jas.
Re: Sideways on ripple strip - damaged chassis?
Postby Lokiel » Sun Dec 27, 2015 1:04 pm
I think you got REALLY lucky and it just looks superficial. Any scraping metal will generate sparks and contacts inside the car always seem louder/worse than if you witnessed them from outside the car, the noise gets amplified massively inside the car.
Might be a good time to think about FM Frame Rails if you're concerned about the bent chassis rail though it doesn't look damaged much (they're great for jacking up the car too - stick the jack in the middle and you can change both wheels/pads on that side).
Postby bruce » Sun Dec 27, 2015 5:01 pm
And this is why I don't do track days anymore.
hamx5ter
Postby hamx5ter » Sun Dec 27, 2015 5:09 pm
+1 for the frame rails..
Not sure that frame rails are strong enough to jack up the entire side of the car though.. I'd love it if they could, but I was given to understand they would bend
Lokiel wrote:I think you got REALLY lucky and it just looks superficial. Any scraping metal will generate sparks and contacts inside the car always seem louder/worse than if you witnessed them from outside the car, the noise gets amplified massively inside the car.
The Green Goblin
Postby The Green Goblin » Sun Dec 27, 2015 5:14 pm
yes as it happened i thought, why the hell am i doing this to myself/car?! but thats part of it i guess.. i wanted a track car, so this is it.
re the FM rails, is the purpose of these purely for reinforcement / protection? do they brace the car in anyway? what is the correct name given to the area that i have bent? (where you place scissor jacks / jack stands), i dont think there is any form of protection for this area?
ta.
Nevyn72
Postby Nevyn72 » Sun Dec 27, 2015 5:27 pm
The Green Goblin wrote:what is the correct name given to the area that i have bent? (where you place scissor jacks / jack stands)
Pinch weld. :wink:
mx5002
Postby mx5002 » Sun Dec 27, 2015 6:46 pm
Most mx5s have worse damage than that from speed humps :lol:
Nothing to worry about.
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
Postby NitroDann » Sun Dec 27, 2015 7:09 pm
It's completely fine. Don't stress.
project.r.racing
Postby project.r.racing » Sun Dec 27, 2015 7:39 pm
frame rail has no dents, so it is fine. the pinch welds are only for holding the panels on. use a rubber mallet and bang it back into place.
most of my lowered cars have had similar damage to them at some stage in their lifetime's.
The Green Goblin
Postby The Green Goblin » Sun Dec 27, 2015 8:13 pm
Thanks gents, as you can tell, I'm a tad precious with it.
Can one recommend a reputable place to purchase frame rails?
Ta.
beavis
Postby beavis » Sun Dec 27, 2015 8:18 pm
I've done similar things in a few mx5's... T1 at Sandown, T9 at Winton...
It's fine. Just superficial. Don't worry about it. Just keep practicing your skills on track.
I wouldn't bother buying bolt on frame rail braces.
Users browsing this forum: miatanut, Red Dragon and 4 guests
