Where to buy special shoulder bolt?
speed
Postby speed » Fri Dec 11, 2015 8:31 am
Hi everyone, my rear suspension is currently out of the car as I attempt to fit nb top hats onto my na6.
Stupid me didn't research first and now I realise I will need four shoulder bolts with a m10 thread (please correct me if I'm wrong) on the inside, in order to extend the threaded section on the na6 struts, so that i can then bolt-on the nb top hats. Guess I may as well get the shorter bump stops whilst I'm at it.
I'm aware of FCM but was hoping someone could advise of alternative places where I could get the shoulder bolts and bump stops from.
Anywhere that will send by express courier would be ideal, so I can minimize my off-the-road time.
Thank you very much,
Steve
Re: Where to buy special shoulder bolt?
Postby hks_kansei » Fri Dec 11, 2015 8:51 am
Personally, there is no way in hell i'd be using a bolt to extend a shock piston (by shouldered bolt I assume you mean somehting with a threaded tube at one end and a longer section of regular thread at the other?)
Shocks, and especially shock pistons, deal with a lot of forces from pretty much eveyr direction, I wouldnt trust a bolt to not just bend/snap over time.
The shock pistons are made from very tough metal to not have to worry about this.
There surely are other ways to do this, while I havent done it myself I know it's a somewhat common NA swap, and I've never heard of anybody using adapters or thread extenders etc.
smy0003
Postby smy0003 » Fri Dec 11, 2015 9:00 am
Could you not just get shorter springs?
Sent from my GT-I9505 using Tapatalk
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
SE
Postby SE » Fri Dec 11, 2015 9:04 am
speed
Postby speed » Fri Dec 11, 2015 10:41 am
Thanks guys, appreciate your input.
HKS, the na6 thread is shorter than nb. The bolt that FCM sell is also an extender is it not?
Sorry, not sure how else I can do it.
SMY I will be fitting lowered king springs but wanted to take advantage of improved rubber mounts that come on the nb top hats.
Worst case, guess I will just install the lowered springs but if I can improve the ride whilst I'm there, I figured I may as well. :)
SE, thanks for the link. :)
Any other suggestions?
speed
Postby speed » Fri Dec 11, 2015 6:33 pm
Think I may just install on the na top hats with lowered springs until I sort out what I need in order to do the nb top hat conversion.
HKS has me paranoid about the structural integrity of the extender bolt, so more research is required.
Better I do this now anyways as
I don't want to fit any parts that could be dangerous.
bear2230
Postby bear2230 » Fri Dec 11, 2015 8:00 pm
Steve, swing by my work next week. Im sure I can help you out.
http://www.fountainlineims.com.au/
Richard.
speed
Postby speed » Mon Dec 14, 2015 12:00 pm
Thanks Richard, most appreciated.
