Lightyear's SE Replica Track/Road MX-5
Re: Lightyear's SE Replica Track/Road MX-5
Postby Lokiel » Tue Nov 10, 2015 12:44 pm
lightyear wrote::
Engine oil cooler is done, with fresh oil. Mounted behind fog light hole.
You really need a small/square oil cooler behind the foglight to allow it to be mounted perpendicular to the incoming air flow for the cooler to be most effective (so that air flows through it).
Currently the air flow will be going around your cooler and not through it since it will take the path of least resistance.
I found the Setrab STD Narrow 25-row Oil Cooler (L:210mm, H:193mm, D:50mm) fitted well (see http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091&start=161)
I added ducting to mine too to force all air through the cooler and not around it - this would definitely help your cooling too since it creates a high pressure area behind the foglight and will force the air to go through your cooler since it can't go around it.
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Mon Nov 16, 2015 7:49 am
The oil cooler has alloy ducting to manage air flow.
The catch can is built now. All that's left is to duct the new radiator, build a new fastback and put the car back into track set up. Oh, and enter an event and win. :)
lightyear
Infinity & Beyond
Postby lightyear » Sat Nov 21, 2015 6:52 am
The ducting is all done, and I am pretty happy with it. It has been opened up a lot, and is pretty well sealed all round. And I have gone from an 18mm radiator, to a 42mm one. So I hope I get some track time without heat issues.
I just entered WRXMAS at Sandown on the 29th Nov. And AROCA on the 13th Dec. Figured I would do Sandown as its close, to make sure the car is working before driving all the way to P.I.
There is a come and try day on the 12th Dec with MSCA, but not sure if that will run as a normal track day.
And the Vic Super Sprint Championship for next year is looking good. They have 10 rounds, inc Winton. And The Australian Super Sprint Championship is at Winton in June I think. Hopefully they get lots of regular competitors.
lightyear
Infinity & Beyond
Postby lightyear » Sat Nov 21, 2015 10:00 pm
Since I had the alloy sheet out, I decided I should finally make the air box. Pretty difficult thing to make due to the angle of the pod filter. But it's nice and secure and should work well. If I get real keen, I might paint it in black wrinkle finish.
free image host
Postby Okibi » Sat Nov 21, 2015 10:07 pm
Looks great Dave, always loved that TDR style intercooler setup too.
lightyear
Infinity & Beyond
Postby lightyear » Sun Nov 22, 2015 8:09 am
Yep, it's better than the normal I/C set up.
This is the duct for the heat exchangers.
img host
Postby NitroDann » Sun Nov 22, 2015 9:15 am
Someone has been reading. Awesome.
greenMachine
Postby greenMachine » Sun Nov 22, 2015 1:00 pm
NitroDann wrote:Someone has been reading. Awesome.
Yes, looks good!
In the lead up to the Supersprint nationals I spend a lot of time sealing up the radiator ducting. The end result was I needed to tape up part of my radiator inlet in order to get coolant temperatures up to an acceptable level. I am happy to live with this inconvenience as an alternative to constant monitoring of temperatures when ambients get too high.
:mrgreen:
lightyear
Infinity & Beyond
Postby lightyear » Sun Nov 22, 2015 1:33 pm
I did the same on my first MX5. I stupidly removed the thermostat as I thought it would help its heat. Then I "V" mounted the I/C. Ran too cool. Blocked half the radiator with cardboard.
If it runs too cold now, I can always turn the boost up. :) This car has a thermostat, so should be fine.
lightyear
Infinity & Beyond
Postby lightyear » Wed Nov 25, 2015 6:26 am
I am making a rear Camm tail for the fastback too. And filling in the bit I front of the tyre on the front spoiler.
lightyear
Infinity & Beyond
Postby lightyear » Wed Nov 25, 2015 4:14 pm
Reworking the front spoiler.
The fastback looks a little unfinished without a rear spoiler. So I am making a low profile one. Will reduce drag too.
Here it is in its rough shape. Needs heavy sanding.
lightyear
Infinity & Beyond
Postby lightyear » Fri Nov 27, 2015 10:16 pm
Just need to do the front spoiler, and it's ready for Sandown.
how to screenshot on windows 7
luzinit
Postby luzinit » Fri Nov 27, 2015 10:43 pm
Impressive! Great work mate
Sent from my SM-G920I using Tapatalk
Postby Okibi » Fri Nov 27, 2015 11:28 pm
:shock: that was quick!
lightyear
Infinity & Beyond
Postby lightyear » Sat Nov 28, 2015 10:27 pm
Car is all ready for Sandown.
upload img
Users browsing this forum: No registered users and 126 guests
