Automotive Plus Coolant Reroute Spacer Thickness
- Roadrunner
- coyotes after you
Can someone with the Automotive plus/MX5Plus Reroute spacer measure the thickness please.
Need to know as I'm looking at the possibility of re-purposing one on the front of the engine as a "sensor adaptor" but need to see if I'll have enough clearance with the radiator hose and fan shroud/bracket as it'll push the outlet housing further forward. Need to know by how much.
MeepMeep
- orx626
- Vehicle: NC - Rotary
- Roadrunner
- coyotes after you
Re: Automotive Plus Coolant Reroute Spacer Thickness
Thank you!
Thats going to make the hose outlet quite tight to the fan shroud I think. I imagine rubber hose rubbing on a plastic edge wont last long.
Was a nice thought though...
MeepMeep
- zossy1
If you converted to the Kia housing, the angle of the outlet might push the hose backward and could clear the cowling...?
- smy0003
Why are you running the spacer at the front?
Sent from my GT-I9505 using Tapatalk
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Roadrunner wrote:Can someone with the Automotive plus/MX5Plus Reroute spacer measure the thickness please.
- Roadrunner
- coyotes after you
Don't have a need for a reroute (yet) figured if I can use the spacer as a sensor adaptor, I get pre thermostat temps and if I do go a reroute in the future, I already have one part of the kit.
Dann, do you keep any of these parts for you reroute option? Spacer and Kia thermostat cover?
MeepMeep
I have one each of those on hand. yes.
- Roadrunner
- coyotes after you
Sweet, I'll try to come up after work this afternoon to check it out if that's ok.
If it looks like it'll clear everything I might take two sets
MeepMeep
- Roadrunner
- coyotes after you
Devastated
The spacer with the Kia thermostat housing is perfect alignment, clears the fans and won't kink the hose......except the bolt holes make it point straight up
Anyone know of a housing exactly like the Kia one but with flipped bolt hole orientation?
Soo close. Gahh
Soo close. Gahh
MeepMeep
- 1600Dave
Kia housing + trip to Repco to find a suitable hose =
Sorry for the highjack.
What aussie delivered Kia is the housing off, is it a mentor and what years?
- Roadrunner
- coyotes after you
speed wrote:Sorry for the highjack.
I believe it is from a US only delivered Kia Sephia.
NitroDann can get them.
I've been googling and came across the outlet from a 94 Falcon 4L. Right orientation for the front of the engine and looks pretty close in size.
http://www.ebay.com.au/itm/Ford-Falcon- ... 0948017274
http://www.supercheapauto.com.au/online ... mendations
Supercheap sell them too. Struggling to find info though on the bolt hole spacing and the thermostat hole size.
Looks like I'm going to have to try to find the time to compare the Ford housing with a mazda gasket at Supercheap to see if the bolt holes line up and if there will be enough meat in the middle to hold the mazda thermostat in place.
Found a pin hole leak in my top hose too so will need to get this sorted very soon.
MeepMeep
- Vehicle: Non MX-5
I would consider a 323/laser thermostat housing. 90-98.
I think I used a laser housing on my car, however the output isn't 32mm it's 26mm I think. So just double check the size of the housing output otherwise you'll have issues fitting the hose. I had a bit of tube welded to the outside so that the coolant hose would fit on. The orientation would be correct though.
You can get inline sensor fittings for the coolant temp. They are cheap on ebay.
